Surprisingly, A2kZ showed up at my door today! On a burn in now for a few days
First impression out of the box is very positive! It got da bass, and it's still there after 2hrs of burn in, very nicely extended down to a textured sub-bass, with a nice fast mid-bass, overall bass is tight, articulate, very well controlled and separated from lower mids, quantity is a little north of neutral, but not too elevated. Lower mids are a bit on a leaner side, while upper mids are very clear, detailed, revealing without being harsh or grainy. Treble is bright, extended, airy (not too much though), and no signs of sibilance. If you push the volume higher (sensitivity is 101 dB, so you need to push it higher) in my "worst" sibilance test track it can get close to being a bit grainy at the top, but never crosses the threshold. Again, I'm talking about absolute extreme here. Overall sound signature is balanced, and the sound is very resolving, revealing, detailed, extended.
So, that's the good part. Here is a bad part - the soundstage. The width is average, maybe slightly above average, but the depth and the height are below average, creating a more close and intimate in your soundstage (closed back, after all). In no way does the sound gets congested, and actually imaging and instruments/vocals placement is not bad. But the staging difference is very noticeable since I have been listening to T5p 2nd gen a lot lately. I keep comparing these two and gotta tell you that A2kZ bass is better and treble is a touch smoother in comparison to T5p.2 while they are both very resolving and with excellent retrieval of details.
Another thing I'm not too crazy about - cables are not removable
If R70x has removable cables, why not make the same with A2kZ?!? According to the spec, ground wires are separated (probably only connected at TRS jack), so would have been awesome to hear how it sounds balanced, maybe that will improve the soundstage expansion. Otherwise, you are stuck with permanently attached 3m cable. Also, no case or pouch. Btw, earpads are the same size as R70x, but no way I'm switching these synthetic leather pads with R70x velor pads, I want to keep the bass without changes
So far, I'm digging these A LOT!!! If they could have soundstage expantion of T5p.2 and also removable cables, similar to T5p.2 or R70x - I would elevated these to the top of my list, for sure! Even EL-8C can't touch them, and in terms of tonality (let's just wait until I'm done with burn in), it will be a hard choice between A2kZ vs T5p.2. Btw, I also like the headband wings, the spring it stiffer in comparison to R70x. Overall, definitely great isolation and no sound leakage (that is one of the problems with T5p.2, leaking sound from bass port, despite them being closed back).
