Muziqboy
Nice! What digital cable are you using?
I got 3 of the Audio Sensibility cables.
Are their ethernet BIOS setting he could look for?
Speaking of when was the last BIOS update you have done?
Is your 3ghz i7 a Haswell or Skylake chipset? WIN 7 or 8.1 or 10?
Try a REDNET firmware rollback to 3.4 and see if that doesn't help.
It seems the RN3 can do 150us and not the RNd16. I found with some experimentation that the 150us SQ is best that 5ms the worst. So this does make a difference. But I was able to get 192k on all RN3 latency settings.
I'm also getting close to 1ms with DVS set for 1ms (but showing 4ms in grey):
Thank you rb2013, but I was thinking about the realtek/gigabyte ethernet driver setting in "device manager" or are these overgone completely by the Rednetsoftware? I don't think so but I am not an expert, only beginner
I've looked in the bios, there's only an enabling and disabling of the internal ethernet card. Cpu throttling is disabled, it's on full-on run mode. There is the cpu virtualization setting but i don't think that's anything for latency, which goes to 15ms in the red for Dante control for the Rednet. I've also disabled the flow control in the Ethernet settings (w10) but still no 192khz joy.
The 3ghz I speak of is Strange's computer who is also getting skips/pops on his 3ghz i7. I'll need to call focusrite and see if i can trouble shoot.
ASIO Latency is not the same setting as Dante Latency. The Dante latency is the latency that shows up under "Device Info" in Dante Controller. You can only change it between 4-6-10ms.
Good question - my machine is a fairly new WIN10 iCore7 - I did not touch the settings. I assume they are all set for 1GB as std
Do you also have realtek ethernet driver? which version? mine is 10.8.311.2016
In device manager -> network adapters -> properties -> advanced.... there are so many settings, as I'm wondering if these could not be configured in order to get lower latency etc.
Yes that is showing 4ms - but I'm getting much better then that - peak 1.1ms and ave 1.1ms
Do you have the DVS set for 2X2? Large ASIO buffer size?
Yes I have all those settings and the Dante latency still spikes from 900us to 15ms and induces dropouts.
Normally not but you should check @Soundsgoodtome. Also check the props of the network adapter: fullduplex & gigabit should be enabled .. also full performance (power setting) for both the CPU and the network adapter.
Check the router too, it may also have some sort of low power mode enabled.
And it could also be that the Dante and/or focurite drivers arent very well written.
without looking at the pc & whole network directly it's almost impossible to say where the issues lie .. but it is surely not the CPU!
Try this tool
http://www.resplendence.com/latencymon
Pretty much the best for investigating audio latency/driver issues. It should be selfexplanatory. With numbers under 500 and no funny spikes your PC can play HD audio .. under 100 is very good. And under 50 you're golden
