rb2013
Author of The 6922 Tube Review
- Apr 12, 2013
I am interested in getting an Antelope Audio Live clock to further improve my setup. Could someone be so kind to give an example of how to connect this into my current configuration. Both my DAC and Rednet 3 have wordclock in and out via BNC connectors. Does one need an incoming signal going into the Live clock? Where would this come from?
My current setup is: laptop and Rednet 3 connected to managed switch, digital out from Rednet 3 to DAC via AES/EBU using db25 cable.
I have never used a master clock and would appreciate any help advice on implementing into my setup. Thanks in advance.
Very simple - run separate BNC cables from Liveclock Wclock outputs (there are 4) to RN and DAC Wclock input. Set the RN to ext clock - not sure on your DAC but should be a switch or jumper.
You are good to go. No input needed on the Live Clock.
