A little offtopic but I found a nice windows tweak today, my NFB15 sounds better with the resolution set to minimum: http://vvvv.org/contribution/windows-system-timer-tool
Very interesting. Bookmarked and I'll try it out at some point.
Have you tried another media player, e.g. foobar ?
I assume that you have put a proper rate entry to Windows / Playback Device / Properties / Advanced.
I also assume the clipping noise is there all time with rates greater than 44.1 khz and not momentarily when you attempt to play music of higher rates.
I would not put too much faith in the IMD test.
I would check whether 192 khz works through coax and then contact Audio gd - they are normally willing to check the issue through remote session.
This is annoying for me to try another. I maybe have to just sit with this 44.1 or 48 or 96 khz.
I've been watching this for awhile, not to minimize the issue, but 192khz is so useless. I own a Master 7 and Yggdrasil and run them both at 44.1khz.
I see. 44.1 is quiet good enough. though, they are advertising that 192khz, 384khz was also available, and I have several 192khz music source.. and In fact, It seems like there's some discrepancy what I'm told and real playback. That was the point.
Yea my M7 was advertised to work with 384khz, but it didn't, only 192khz and below worked.
The thing is, all digital releases (as far as I know) are released as 44.1khz. Some people upsample those to 192khz, but that's meaningless.
The only real 192khz recordings are rips from vinyl, and 192khz is overkill for that.
Anything higher then 48khz was never intended for playback, it was to give mixing / mastering artists overhead when editing in the studio.
The guy that wrote this article is arguably a genius, he created the OGG format:
https://xiph.org/~xiphmont/demo/neil-young.html
If you still want 192khz after reading that, I'd say your only option is to send it back to have it factory tested =/
