petemac110
- Apr 23, 2011
Kingwa's WM8741 DACs sound great. I owned the older NFB-3 and have heard numerous iterations of the NFB-2. I find the WM8741 implementations to be a bit warmer and less detailed overall than the current NFB-3, but they are very good sounding DACs.
I'd be inclined to go with the current NFB-3 if you can manage it. Yes, this is a generalisation, but you're unlikely to overcook things in the detail/resolution area by matching the revealing NFB-3(2014) with a tube amp. Instead, the two should synergise quite well.
Re: The NFB-17, do you actually need balanced outputs in your system?
