i019791
- May 25, 2012
After emailing back-n-forth with Kingwa, I went with the NFB-10.33 over the NFB-28. While I have heard the WM in the past and enjoyed it, I never heard the ES.
There was also the price difference (which I am on a budget). Add in the fact that I didn't need the analog input stage, but I am running it as a balanced pre-amp out to dual active cross over-amps, the 10.33 had the dual XLR output stage.
I know many of you are fans of the ES dac over the WM, but I think I made the right choice. Perhaps when I get some more money I will get an ES dac as well. Would be nice if the NFB-28/10.33 configuration had a swap-able dac like the Compass.
Thanks again for everyone's help and input.
Regards...
Theonly issue with the 10.33 is that if you decide to change your dac you will have to change the amp too
