lukeap69
- Feb 15, 2014
Dame, the screenshots didn't show up in my post. You can see the screenshots here https://app.box.com/s/o8kqxk7ondq6a4b5q43m
Bummer! Audio-gd informed me that Chinese custom is having a serious check of all goods so my NFB-1 will be delayed by 5 to 10 days...
I followed your screenshots and set it up the exact same way, still getting an error saying this sample rate not supported by dac. this is frustrating. I dont understand the problem. Im starting to think its a problem with the USB32 receiver. I uninstalled all other sound drivers and made sure its using the Audio-GD ones. Still no go.
So i tried everything... But im making some progress. I had no luck with the VIA ASIO driver. So I tied ASIO4ALL V2.
Using ASIO 4All I got everything but DSD working (24/96 24/176, 24/192 works perfect). So im pretty happy for now, but DSD support would be nice.
Still waiting on another reply from King-Wa.
But this NFB-1 sounds great so far.
Thanks for all the help!
So I was successful installing the drivers to my wife's laptop. I have captured screenshots during the installation and setting up of the drivers and components https://app.box.com/s/8gn0g542pmic1vumixi5
You will see that by just following the installation instructions of Audio-gd, hires FLACs are already recognised but not DSD. The additional steps on the link above is for the DSD to be recognised and played.
Hope you can sort out your issues as NFB-1 is a great DAC.
You can cue them all up, there is no need to chance the settings. Although the popping sound is there when a DSD song starts or ends. It is annoying. Having said that, I also get pop even on my Mac using Amarra or Audirvana plus.
Interesting post re pop and DSD.. http://ifi-audio.com/audio_blog/pop-goes-dsd-why-does-this-happen/
