I have really high hopes for the 75Ohm out. My afterdark X1 needs this!
Audio-gd DI24/DI24HE
- Thread starter FredA
FredA
- Dec 15, 2013
Yeah. I will run another test removing synch by selecting the internal as outputted clock. This issue is this can make my streamer freeze. It needs a constant signal clock. I will also compare with direct clock out. Soon.This is the part that I'm really interest in. In theory, that would sync the clocks for the two devices and should be good. Thanks.
sajunky
He obviously tested it, otherwise it wouldn't be such option.Another piece of info. I spoke to Kingwa about outputting the external signal from the di24he. There is a rebuffering occuring and noise can possibly go down by using this output instead of going directly out of the clock.
FredA
- Dec 15, 2013
Good point.He obviously tested it, otherwise it wouldn't be such option.
So there is two types of clock outputs...both comes from the DI24HE?Yeah. I will run another test removing synch by selecting the internal as outputted clock. This issue is this can make my streamer freeze. It needs a constant signal clock. I will also compare with direct clock out. Soon.
FredA
- Dec 15, 2013
You have the choice to output the incoming external clock if one is connected. If two are connected, you get the selected one i guess. Otherwise, the only choice is "internal". This outputs from the built-in 10M generator.So there is two types of clock outputs...both comes from the DI24HE?
@Cryptkeeper
I bought that furutech 106-d wall plate cover for $70 on amazon, burned all my rewards points on it.
FredA
- Dec 15, 2013
Well worth it.@Cryptkeeper
Lol my bad, wrong thread.Well worth it.
JPlaquia
- Jan 28, 2015
That means I am keeping my DI20HE for sure - thanks for this info!
but the port says “multiduty” specifically on 75Ohm input.
Yeah that "Multiduty" is something noteworthy, it doesn't say on the site what that means but hope it is a multi function like spdif-clock input combo.
Also I saw some coax to usb adapters, does that work? Is it okay to use something like that?
sajunky
Multiduty, multi purpose or multi function as you wish. I expect it will require flashing specific firmware to change function rather than having selectable option on the menu. S/PDIF is a primary candidate. Both for input and/or output.Yeah that "Multiduty" is something noteworthy, it doesn't say on the site what that means but hope it is a multi function like spdif-clock input combo.
If you mean USB to coax converters, yes. Like Douk Audio U2 / Pro or Matrix S/PDIF 3.Also I saw some coax to usb adapters, does that work? Is it okay to use something like that?
JPlaquia
- Jan 28, 2015
Yeah it for sure requires a firmware to make it work like an spdif.Multiduty, multi purpose or multi function as you wish. I expect it will require flashing specific firmware to change function rather than having selectable option on the menu. S/PDIF is a primary candidate. Both for input and/or output.
By coax to usb adapters I am not referring to the matrix, but rather something like this. I saw some from aurrender as well
but kind of expensive, this one's pretty cheap.
sajunky
Looks different, but works exactly the same. Question should be raised about clock. It is a place where synchronous datastream is created, so clock is important. With U2 you can order ultra-low jitter clocks version. A Pro version can also work as grounds loop redirector (a poorman DDC) if used with external power supply.By coax to usb adapters I am not referring to the matrix, but rather something like this. I saw some from aurrender as well
Hengstenberg
Incoming R8HE MKIII next week.
Do i need mandatory a DI20/24 to unleash the beast or is the unit fine as it is, so can live easy without it?
mainly because i have a little problem with buying 1 unit and then i need e second unit for unit 1 to sound good.
Any opinions?
Any opinions?
FredA
- Dec 15, 2013
Not needed. A bonus.Incoming R8HE MKIII next week.
Any opinions?
Total: 17 (members: 5, guests: 12)
