Maybe they told you while preparing it for you. Surprised you did not askyes, the spdif input replaces the 75 ohm input.
for the other question I still don't know why it has to come to me
Audio-gd DI24/DI24HE
- Thread starter FredA
FredA
- Dec 15, 2013
The 50-ohm clock input remains. Same for the two clock outputs.yes, the spdif input replaces the 75 ohm input.
actually I don't think I will use these two outputs. At the moment I only plan to connect both the DI24 HE and the R26 Gustard to my afterdark master clock.Maybe they told you while preparing it for you. Surprised you did not ask
BiscuitHammer
I just updated my unit with the new firmware provided from AGD website. After following the guides posted in the thread, I have successfully updated the firmware (according to the message from the Quartus software).
After finish updating the firmware, now my unit is not recognized by my computer anymore (running Windows 11). Does anyone have encounter the same issue?
Jandu
- Aug 13, 2010
Assuming you are using USB, just reinstall the USB driverI just updated my unit with the new firmware provided from AGD website. After following the guides posted in the thread, I have successfully updated the firmware (according to the message from the Quartus software).
BiscuitHammer
I did try to reinstall the Amanero USB driver but it still doesn't work. Retried installing the update again but still nothing
Does the display show the normal/stock information as before?I just updated my unit with the new firmware provided from AGD website. After following the guides posted in the thread, I have successfully updated the firmware (according to the message from the Quartus software).
Maybe it switched to SPDIF as input?
mivarpet
- May 22, 2015
Did you press the little button next to the update port? That will wipe the USB Amanero firmware which could explain why the device is no longer recognised.
FredA
- Dec 15, 2013
You will likely have to re-flash the Amanero. Follow http://www.audio-gd.com/Firmware/AmaneroforWinEN.htmI did try to reinstall the Amanero USB driver but it still doesn't work. Retried installing the update again but still nothing
BiscuitHammer
Thank you for the info! I did press it when I was updating the firmware. I thought I need to press the button when plugging the USB blaster to the unit. Let this be a lesson for anyone else that is trying to upgrade the firmwareDid you press the little button next to the update port? That will wipe the USB Amanero firmware which could explain why the device is no longer recognised.
Thank you so much for the help, my unit is working properly now! So far I'm loving the sound quality upgrade from the new firmware
Note to self : do not press the update port button.
I was always afraid of that buttonNote to self : do not press the update port button.
...wait a minute my R1N has this port....OOOH my if Kingwa improves on this! - DREAM!
-Still more than satisfied though with the stock
Currently only firmwares for the non-NOS
http://www.audio-gd.com/Firmwaredownload.htm
Hi,
I have installed quartus 13.1 on laptop as 12.1 is no longer available.
I connected the blaster to the input socket on DI-24 and the usb cable to laptop that has windows 10. Started the Quartus software and when I select programmer then hardware setup and use the drop down menu for currently selected hardware nothing is available just has the No Hardware option?
Have I missed something as I want to upgrade the firmware?
Thanks
Thanks
FredA
- Dec 15, 2013
Usually, it is because the driver for the usb blaster is not properly installed. Uninstall it from the device manager and have windows search for a driver within the Altera folder.Hi,
Thanks
Hi, Did that a few times and when I select the folder in the altera for the drivers it just keeps saying the best drivers for your device are already installed. This is in Device manager of usb blaster.Usually, it is because the driver for the usb blaster is not properly installed. Uninstall it from the device manager and have windows search for a driver within the Altera folder.
