Audio-GD DI-20
Apr 5, 2024 at 5:42 AM Post #5,266 of 5,351
Did you try ext. clock on DI and I2S (no ext. clock) on a DAC?
Just switched following your advise. I don't dislike it, that's for sure: sounds dense and airy at the same time.. interesting.. Sounds like another viable option.. Did you have any specific technical reason in mind suggesting it?
Apr 5, 2024 at 8:42 AM Post #5,267 of 5,351
Yes, sort of, because I don't know details of this particular implementation. From analysis of other posts it appears to me that there is no PLL synchronisation with internal clocks on the I2S connection, just a simple phase alignment of the I2S clock to sample data just in the middle of a cycle, not close to the edge. In a simple terms DDC is a master clock for a DAC. There is added jitter on a connection plus the isolator, but if more sophisticated methods do not bring good results, make it simple, stupid (KISS). Universal rule. I remember that @FredA was using such connection and his opinion raised my attention.
If external clock is enabled a DAC is forced to use its internal clock synthesiser for a full reclocking with PLL. If it doesn't work well, it is a sign that something needs to be working on. I expect that after a feedback from DI-24 (where technology is tested) new firmware will be released modifying clock synthesiser operation in DAC's. Kingwa should give us indication when such changes are implemented, as it would change the optimum option.
The above is valid on the I2S connection with a first grade short cable. S/PDIF connection carries more jitter, in this case both devices should be synchronised with external clock for the best result. If doesn't work this way, then there is something more wrong than I thought.
Apr 5, 2024 at 11:49 AM Post #5,268 of 5,351
4.075 has very good instrument placement. Be sure to set it to Parallel in the DI20 settings. Serial is just weird with the timing/rythm.
This firmware makes instruments easy to "follow".
The surround/3D is real
Apr 5, 2024 at 1:22 PM Post #5,269 of 5,351
I remember trying all the versions up to v4.076 and found v3.933 the best for me (liquid and rich sound, compared to a bit dry for my taste v4.075 and v4.076) What do you like about v4.075? Maybe I should try it again some time..
DI20 on 3.933 is nothing....I could live without the DI20.
Matrix SPDIF-3 betters it at that version of firmware. Wow it is boring man. I rather use the R8 without the DI20. Not joking. Everything is floating into each other.
Instrument placement level: 0% - Just another DDC.
Forever 4.075 :heart_eyes:
EDIT:
DI-20V3.99
(June. 2020)
Better than, 3.933. Same amount of sweet bas but more musical, very nice rythm. This one could challange 4.075
Apr 5, 2024 at 1:47 PM Post #5,270 of 5,351
LOL Bud,:beyersmile: I bet, in a blindtest between 4.75 und 4.76 you would epic fail, haha
Best sounding FW to me is 4.76, but anyway, sold my DI20HE today because my R1N sounded worse with it. lol :k701smile:
I need a DAC with clock input, without the DI20/24 seems worthless to me, so i´m a little depressed today :frowning2:
Apr 5, 2024 at 1:47 PM Post #5,271 of 5,351
EDIT:
DI-20V3.99
(June. 2020)
Damn you, you make me flash it again from 3.933 to 4.075
How's the highs? I'm very picky about treble being too much or harnesh or piercing or..... You know......
Apr 5, 2024 at 1:56 PM Post #5,273 of 5,351
DI-20(non-he) betters the DI20HE in the highs of the R8H2. More air! - I find the 4.076 unforgiving has a weird rythm. I should have tried it in serial mode.
I am not testing R1N.....R8H2 has taken the lead with DI20....Clearly 4.075 was the version my DI20HE came with..
I am on 3.99 now. Seems more soundstage deeper....less floating/bloating than 3.933
Apr 5, 2024 at 2:01 PM Post #5,274 of 5,351
I am on 3.99 now. Seems more soundstage deeper....less floating/bloating.
What now? Are you in love with 3.933 or 4.75?
It seems this is changing every hour, lol:beyersmile:
Apr 5, 2024 at 2:03 PM Post #5,275 of 5,351
You clearly don´t know how open the DIs are.
Your source is everything you can blame when it comes to AGD. Nothing is hidden. Get er Audiophile PCIe card stop using the motherboard USB....
I was like you in the start of AGD journey...You will change you mind more often with a bad source
Apr 5, 2024 at 2:04 PM Post #5,276 of 5,351
Bad day?
4.075 and 3.99 so far is good. But 4.075 is my favorite
Apr 5, 2024 at 2:07 PM Post #5,277 of 5,351
Your source is everything you can blame when it comes to AGD. Nothing is hidden. Get er PCIe card stop using the motherboard USB....
lol, bud, i don´t blame AGD :beyersmile:
R1-NOS sound is so incredible, it don´t need a DDC, DI20/24 or pink faun snake oil 😂
Audio GD R1N DAC is Kingwa´s magic box from the matrix 🧙‍♂️🪄
Apr 5, 2024 at 2:08 PM Post #5,278 of 5,351
The R1-NOS sound is so incredible, it don´t need a DDC, DI20/24 or pink faun snake oil 😂
Good luck and enjoy your music :L3000:
Apr 5, 2024 at 2:23 PM Post #5,279 of 5,351
I see you have different chain than mine.
I use SPDIF input and the differences are soo obvious I am pretty surprised.
