steveting99
- Dec 9, 2012
I've noticed on Audio-GD's website for the Compass 2 that it states both the Sabre ES9018 DAC as well as the Wolfson dual WM8741 DAC. Wasn't sure when purchasing the unit, it comes with both ES9018 and dual WM8741 DAC?
franmon83 indicates that the dual WM8741 is a separate purchase - question for franmon83 is how did you select between the two different DACs? Did you have to physically swap the ES9018 out and put in the dual WM8741? Or is there a switch within the unit that allows you to select the type of DAC you'd like to use? There doesn't appear to be a physical switch at the front/back of the unit that allows the user to easily select.
I'm interested in either the Compass 2 or NFB 11.32 because of the ES9018 DAC. Can't tell much of a difference between the Compass 2 and NFB 11.32, except for a larger power output on the headphone.
