No worries, you can count on Kingwa to replace it with something newer and better, eventually.
Audio-gd Compass 2 amp/DAC Impressions thread
- Thread starter franmon83
jodgey4
- May 2, 2013
I'm guessing there'll be something new, considering all of his WM8741 products are on the way out. He needs a cheap dedicated DAC to pair with the NFB-3AMP at ~$250 shipped IMHO. Like a DAC-only NFB-11.
JoeDoe
- Apr 12, 2013
Hello gentlemen,
I've just come into a secondhand compass 2 and I'm unable to get audio from the USB on my 2012 MacBook pro. Anyone else out there able to offer advice?
jodgey4
- May 2, 2013
Do you know which year your model is? The old drivers should be on the site, once you identify the right ones. Kingwa is pretty helpful with that stuff.
JoeDoe
- Apr 12, 2013
Mine is a 2012. Problem is installing drivers in the apple ecosystem.
jodgey4
- May 2, 2013
I thought Apple didn't even need drivers? I should stay out, this isn't my area. Sowwy.
JoeDoe
- Apr 12, 2013
Well that's what I thought but so far I can't get any audio through USB. Kingwa suggested installing new firmware but I'm not sure he completely understood my issue.
jodgey4
- May 2, 2013
Is your laptop recognizing that you even have something plugged in? If you can't get it to recognize the device, flashing firmware could fix that.
JoeDoe
- Apr 12, 2013
It does recognize it. Both in system preferences and in JRMC
JoeDoe
- Apr 12, 2013
So here's a weird one. I updated to El Capitan on the MBP just to see if that'd change anything. (Don't worry, I have Mountain Lion on my backup HD).
USB is working fine except that the only way I get audio out of the Compass is if the Line-in button is pressed! Luckily, I'm probably never going to use the 'real' line-in function, but still, this is a little weird.
The button could be inverse of what you think. My C-2 Class A had a button that was in for off as well. Or it might have been the Ref 5. Either way, some of the older Audio-GD stuff was weird like that.
JoeDoe
- Apr 12, 2013
I gotcha. That makes me feel better. Thanks for the heads up!
By the way, back when they were being sold, how much did the other DAC modules cost?
Around $1000. He stopped making standalone 4x PCM1704UK balanced dacs shortly after the price on the chip went up.
JoeDoe
- Apr 12, 2013
Sorry I wasn't clear, I meant the swappable DAC boards for the Compass 2.
Bananiq
- Nov 3, 2008
is this dac/amp still comparable to newer ones? nfb-11?
