Audeze SINE Series
Apr 20, 2016 at 10:07 AM Post #856 of 4,785
Hello @funksoulava
Finally someone, who seems to like, what I like ! I understand you currently own SINE, right ?
Can I ask you for little test ? Here is song: https://www.youtube.com/watch?v=VDQE-IWmZnU (this is pure definition of dubstep for me)
Can you please kindly describe for me, how does it sound using SINE ?
I am interested in separation of drum from other higher frequencies, how is bass "punchy", and how does final drum fade-out sounds for you in SINE.
Maybe this headphones are what I am looking for, but I don't have any possibility for some short listening to them.
I will very much appreciate your comments.
Bobi
Hi @BobiBolivia,
Unfortunately, I'm not into dubstep and can't really define how the song is to me. Sorry.
Apr 20, 2016 at 2:05 PM Post #858 of 4,785
I've actually used the internal case of the DN1 Pro (the case I recommended from Amazon that is the video above) within other bags to maintain the slimmess of the Audeze Sine.  It works great inside a front pocket of my Filson 72 hour briefcase.
Apr 20, 2016 at 5:43 PM Post #859 of 4,785
I was at an Apple store today and tried on the Audeze EL8.  It was a lot tighter on my head than my LCD3.  That said, is the new Sine series wearing more like an EL8 or LCD3?
Paul
Apr 20, 2016 at 10:46 PM Post #860 of 4,785
Paul
Well the SINEs are 230g and the EL8's are 460g, which are both lighter than the LCD-3's at 550g. Also the fit of the SINE's is much different from the LCD-3's. The LCD's primarily sit on top of your head, whereas the SINEs kind of clamp onto your head as an on-ear.
Cheers
Apr 21, 2016 at 9:03 AM Post #862 of 4,785
Apr 22, 2016 at 4:26 PM Post #865 of 4,785
Somebody must know me at Audeze! I ordered the Sine with cypher on saturday and i just got the Fedex delivery notice. I should be able to do a good comparison with the PM-3s. I will also be getting a HIfi Skyn for Iphone6. It will be a fun month!
Apr 22, 2016 at 6:57 PM Post #866 of 4,785
@osvaldo
 Did u try with the balanced out of the  DP X1? I didnt get the cable for it.
Really loved the Sine when paired with the DP X1. But I had to run the X1 at  high (130+ ) to get a decent volume and this took a tool on the battery life(it went from 95% to 50% in like three hours, 20min screen on  )  .
The Fiio Q1 run the Sine with better authority on half volume (high gain) ( slightly lower SQ then the DPx1) .
DPX1 is a very good android based DAP but I really cant understand why onkyo would put it up with 1630mah  battery .The Fiio X1 has a higher  battery capacity  than the DPX1.
So returned the DPX1 and started the search for a good DAP again to go with my Sine's.
Qp1r - sensational combo.
Apr 22, 2016 at 7:13 PM Post #867 of 4,785
Apr 23, 2016 at 6:30 AM Post #869 of 4,785
I had the PM-3 for three weeks and really liked it, but just didn't quite check all the boxes so sent it back while I was still within the 30-day window. I've been eyeballing the Sine and the Headfonics review may have just sent me over the edge. I'll probably try that the second I see it appear on Amazon (I've got lots of credit there I've got to spend).
For those of you who have had both, I am curious for direct comparisons.
Now I just need to determine if I go a bit crazy and spring for Mojo, or if the new Dragonfly Red will be more than enough for me.
Apr 23, 2016 at 7:19 AM Post #870 of 4,785
I was one of the odd guys out. I tried to enjoy the PM-3 and actually bought and sold or returned three times. The final time I had some repair issues so I just returned them.  To me there was no fun, kinda boring. On the contrary I thoroughly enjoy the SINES.
