Audeze SINE Series
- Thread starter mammal
- Tags
- audeze audeze-sine sine
Tomerco
- Dec 1, 2008
I own a pair of LCD 2C's and iSine10 bought a pair of Sines based on the lush sound I was getting from them. Unfortunately, I found the stock pads on the Sines uncomfortable so I have been experimenting with different pads, mainly Brainwavz pleather and the hybrids. The pleather were ok but the treble on the hybrids had too much shrill so counted them out. I also found a pair of angled pads and for me these hit the spot perfectly, they are super comfy and improve the sound signature, certainly doesn't degrade it. I know other people have commented that the Brainwavz are Meh, but thought I should share my experiences in case anyone else wanted a recommendation.
did you get the angled pleather or leather? a link will be great, Thanks!
mcook1970
Angled pleather: Brainwavz Angled Memory Foam Earpad - Suitable For Large Over The Ear Headphones (Black Pleather) https://www.amazon.co.uk/dp/B00ZY8PGJI/ref=cm_sw_r_cp_apa_i_avkkCbSQTXBN9did you get the angled pleather or leather? a link will be great, Thanks!
fljoe
Thank you @kingdixon & @Double C . I ordered the same one as it is half price now @$49.50 at the Meze store (https://www.mezeaudio.com/collections/accessories/products/99-series-2-5-balanced-cable)
BRSxIgnition
Has there been any rumor of Audeze working on a wireless/over-ear Sine headphone?
clerkpalmer
- Dec 16, 2015
I hope that Audeze does this. It would sell like hot cakes. The Mobius is awesome but I want something portable and more subdued in appearance. A sine successor with Audeze dsp and bt would be a home run.
dabaiyan
Does anyone know if this cable will fit the sine? hhttps://www.amazon.com/dp/B07H6SPVX5/ Thanks
BRSxIgnition
Honesty I feel the same way - if they combined the wireless and over-ear factors from the Mobius with Sine styling, materials, and build quality and offered it at the right price, they could really sweep the premium portable space out from under Bose, Sony, and others.
How about it @Audeze ?
Ken G
It works. I had bought the cable a few years back for a different headphone and just tested it on the Sine. Works fine.
BRSxIgnition
Got to try a Mobius today.
Love the sound, soundstage, soft earpads, and features.
Don't love the 10 hour battery life, or creaking and cracking headband on both available demos.
Would be nice if we got an over-ear wireless sine to fill that gap between the two.
TidalWave
- Jun 7, 2014
Just got an iPhone SE to use as a music player with the Cipher cable (prior to that was using a DAP/amp stack for a long time). The Cipher is a bit on the bright and mid-forward side, sometimes a bit painful to listen to, but I do enjoy the extra DSP that seems to highlight fine detail and gives a sense of "dimension" and soundstage more, since presumably it was customized to work exactly with the SINE and an i-device. I of course got greater power / impact with my Cayin C5 amp, but no benefit of the custom-tailored DSP.
I'm curious about power draw of the Cipher cable and how it reflects on battery life of your phones. It looks like the Audeze HQ app inaccurately lists Sine and EL-8 as eligible headphones to use with the newer app, as they don't use Cipher V2 cable, right? Only the iSine models use Cipher V2. Cipher V2 had some power draw / battery life optimization over V1 from what I've read. Can only use the older, original Audeze iOS app to control the Sine Cipher cable, probably without the updated battery life benefits
I have Mobius as well. Absolutely no headband creaking issues. Been in use for close to four and a half months now. Maybe the demo units got used abused to get more creaky.
borrego
- Jun 19, 2008
I received my pair of special priced $279 Sine DX this morning. I am surprised by the triple boxed packaging. This is the nicest/most protective packaging I ever have from a headphone manufacturer. A nice enough carrying case is also included.
A quick listen to it tells it is more or less in the same sound quality segment of higher end L cusion Grado, it is not as dark sounding as I expected. Burning it in right now with 20Hz-100Hz tones to lossen up the diaphragm (if it makes difference). I am happy so far. I think at the current price it is better value than Grado SR225/SR325/RS2e/PS500e range.
Are Sine very difficult to drive? Something strange is going on with them. I have to turn the volume all the way up driving them from Antelope Zodiac or Bryston b60 but not so from Chord Mojo.
tsiyoshi
A quick listen to it tells it is more or less in the same sound quality segment of higher end L cusion Grado, it is not as dark sounding as I expected. Buring it in right now with 20Hz-100Hz tones to lossen up the diaphragm (if it makes difference). I am happy so far. I think at the current price it is better value than Grado SR225/SR325/RS2e/PS500e range.
I also ordered these a few days ago. at that price point, I thought it was a good buy, but found it a little difficult to find many reviews for the DX version. Very curious to hear how they sound!
Total: 14 (members: 0, guests: 14)
