Hi, no, I am using the standard 3.5mm connection. Can you please share what balanced cable are you using?
I made my own cable.
DX200 +Amp8 is a pretty good match also.
I'm having a problem with my Sine where the left channel audio is getting cut off. It can be easily fixed by fidgeting the connector and moving it around but i realized it's not the actual connector that is the problem as I flipped the cable, put the left plug in the right one and vice versa. The left channel is still getting cut off which leads me to think it's the actual left cup that is problematic. Has anyone experienced the same or has any suggestions?
(I hope my explanation isn't confusing)
Do nighthawk and nightowl the same earpads? I put the earpads of nightowl on sine but they are too big. ThanksThe ultimate mod Wider soundstage and better imaging. :
