i4 is too expensive for what it offers
Audeze LCD i4 TOTL In-Ear Monitor Discussion
- Thread starter Emerald Core
AussieMick
Because?i4 is too expensive for what it offers
wdym because its just to expensive for the performanceBecause?
AussieMick
What outperforms it for less with the same sound signature?wdym because its just to expensive for the performance
Not sure what you're working with, but the effort is worth it...i would not let go of mine.That's exactly what I'd like to do, but I am having trouble getting my first EQ to work.
- Mar 12, 2009
Do share!I've saved multiple EQs in my DAPs for my i4. This way it's plug and play.
rebbi
- Apr 11, 2016
I agree completely! I actually just returned a pair of Hifiman Arya Organic full size, open back headphones. Although they are great for what they are, my LCDi4's wipe the floor with them in almost every respect, IMHO. I mean, it's not even close. Fortunately, I was able to pick up an open box, unused pair of LCDi4's from a seller on US Audiomart, at a little over 50% of the retail price. I know it's trite to put it this way, but I literally can't stop listening to them, they are that wonderful.Not sure what you're working with, but the effort is worth it...i would not let go of mine.
Has anyone tried some type of ear muff/cup thing over these? I'm curious if there is a way to get a tiny bit of noise isolation while using these.
makan
- Feb 16, 2015
Ok. I bought a usb c to lightning connector for my iPhone 15…it connects and recognizes the adapter but no sound via the cipher cable. The adapter advertised that it is for audio only as well.
This is the one I bought. Photo attached
Has anyone bought an adapter that works other than the official Apple one which is higher priced?
- Mar 12, 2009
If you’re looking for isolation, you have the wrong productHas anyone tried some type of ear muff/cup thing over these? I'm curious if there is a way to get a tiny bit of noise isolation while using these.
Yeah, I know. Just wondering if I can cut out a teeny weeny bit of background noise in the office. I thought some muff thing might keep most of the benefits of open back while not being much bigger than a normal headphone.If you’re looking for isolation, you have the wrong product
Hey, I just checked on my iPhone 10 to see if my version of Audeze HQ app would still work with cipher cable, I have 2. At first, it looked like it wouldn't work and was looking for BT headset of Audeze. Then after I correctly oriented the Cipher plug I saw the 10 band eq with preset buttons, settings button, I don't remember if I had to click on Reconnect? I checked both cables and the app was able to see both of them ad their separate EQ settings. I clicked on settings in the app and it showed both had 5.1.7 firmware or something like that, and the App version at 1.4.3. Anyone know how to get this app off the phone as an .ipa? Might be helpful for some. I'm currently running iOS 16.74 Also, does anyone know what the last firmware update for the cipher cable is? I got an error when I clicked on check for update...Oh, maybe I was unclear. I can listen to music, it works just fine sounds great, in fact. It's just that the app refuses to connect with the Cipher cable. When I looked at the Apple App Store, the Audeze HQ app is rated at, like, 2.5 stars. So it seems like maybe Audeze has just stopped developing it and it's pretty broken at this point. But I'll be curious to see if anybody is still able to get it to work on an iPhone. Thanks for responding!
Devodonaldson
Anker made one a couple years ago. I was using cipher cable with my Android phone in 2020. So, Amazon Anker Lightning to USB c adapter. It may still be availableOk. I bought a usb c to lightning connector for my iPhone 15…it connects and recognizes the adapter but no sound via the cipher cable. The adapter advertised that it is for audio only as well.
makan
- Feb 16, 2015
Thanks...Audeze customer service recommended that one...but I think I am just going to pony up the extra cash and get the apple one. I find off-market ones may only work for certain hardware and ios versions....I just wanted to see if anyone had one that worked with the current iphone 15Anker made one a couple years ago. I was using cipher cable with my Android phone in 2020. So, Amazon Anker Lightning to USB c adapter. It may still be available
rebbi
- Apr 11, 2016
I finally figured out how to equalize. I installed Poweramp Player from the Google Play Store on my iBasso DX320, which comes with many, preconfigured equalization profiles for various headphones, including one for the LCDi4 created by the reviewer Crinnacle, himself. It sounds great, amazing, even. Also, the separate Poweramp Equalizer will grab output from Spotify, so that's also a win. Unfortunately, I haven't yet found a way to equalize streams from Tidal. ![Confused :confused: :confused:](https://cdn.head-fi.org/e/people/confused.svg)
