mlxx
- Apr 7, 2012
You still want an amp with the least output impedance as possible to make the most efficient use of its power, for low impedance planar headphones (20-50 Ohms). So for solid state amps, the best ones are <1 Ohm, with tube amps this gets harder to achieve due to coils etc in the tubes, most OTL amps are no go for planars. If you have a high amp impedance (say >100 Ohms), power is wasted in its output impedance and goes up in heat when paired with a low impedance headphone. The LCD3/4 at 110 Ohms plays a little better with a larger variety amps (works with some tube amps) but it still depends at which impedance the amp is able to supply its power, so need to always check check the amp's specs for the headphone being used. Generally speaking, amps with a high output impedance won't be able to supply enough power to a low impedance without a lot if it getting wasted as heat, so although a low or high output impedance may sound the same for a planar, the low output impedance amp will be able to supply more power, all other thing being the same.
