Attenuator for RE2?
Sep 8, 2008 at 5:08 AM Thread Starter Post #1 of 9
tjhmuse
The RE2's are pretty much at the highest I would want to listen at the lowest volume setting on my Zune 30. I've been trying to find a level attenuator to use. Any suggestions on where to look? I searched the IEM forums, but didn't have much luck, other than a few posts about the attenuator that comes with Shure. Basically looking for a 'universal' attenuator that would work with the RE2's.
Sep 8, 2008 at 5:36 AM Post #2 of 9
There is another one that is made by Audio-Technica but they are a lot more difficult to find. You can also consider adding an inline resistor adapter.
Sep 8, 2008 at 2:59 PM Post #4 of 9
Oddly enough, Head Direct has a nice 75 Ohm cable (DW04) for $25.
I'm using it right now in between RE2s and a Cowon D2. Phones straight out of the D2 are comfortable listening at 06/50 volume. With the 75 Ohms I can bump it up to maybe 09/50. So not much difference, really.
Just got these a few days ago and most of my listening has been Cowon D2 > iBasso D2 Boa > RE2s.
I guess all I can say is you'll need a fair bit of impedance to slow these down.
Sep 8, 2008 at 4:13 PM Post #9 of 9
Originally Posted by tjhmuse /img/forum/go_quote.gif
Is this the Audio-Technica item you are talking about, ClieOS?
Buy Audio-Technica AT8202 Adjustable Inline Attenuator at Musician's Friend
This is the one I am talking about:
audio-technicaF»•iî•ñ AT3A45ST
