Astell & Kern SE100: A&futura Impressions - Reviews
Apr 5, 2021 at 11:35 AM Post #1,471 of 1,572
The music library is replaced every time it scans. This happens pretty much every time the player is off for a decent amount of time. Say 24+ hours. After it scans its fine, but scan takes hours to replace all the music.
even after completing a manual scan?
Astell&Kern Stay updated on Astell&Kern at their sponsor profile on Head-Fi.
https://www.facebook.com/astellnkern/ https://twitter.com/astell_kern https://www.instagram.com/astellnkern.official/ https://astellnkern.com astellnkern@astellnkern.com
Apr 5, 2021 at 9:58 PM Post #1,472 of 1,572
@JasonNYC
I have a Problem with USB Out to a TH1ES SE100 stops casually every 2-3 minutes when playing (on all output wit apk or embedded player)
Before Hardware reset tested today with SE200 and It Is the same.
DX220 works fine, so It doesn't depend on Cable or AMP...
SA700 works also fine but the best sound and battery life Is from SE Series so please help.
Thx in advance
Apr 6, 2021 at 1:49 AM Post #1,473 of 1,572
Apr 22, 2021 at 9:09 AM Post #1,474 of 1,572
Astell&Kern has identified the issues users are having with the embedded Tidal app. Tidal has changed the authentication method used when logging into third-party Tidal apps. Astell&Kern is working as quickly as possible to make the required changes in the embedded app.
New firmware updates for the SP2000, SP1000, SP1000M, SE200, SE100, SR25 and KANN ALPHA will be released in May 2021, which will contain an updated embedded Tidal app to fix the authentication issues.
There is an issue with the new Tidal authentication policies on the following players – KANN CUBE, SA700, SR15, CT15 and CT10. We are looking into ways to continue to support the Tidal app on these players. More information will be available in May 2021.
Tidal is dropping support for older model Android devices. Unfortunately this means Tidal can no longer be supported on the following players due to the new authentication requirements - AK380, AK320, AK300, AK70 MKII, AK70, AK240, AK120II, AK100II.
Apr 24, 2021 at 9:13 AM Post #1,475 of 1,572
Talking about Tidal: Does the Open Service Tidal deliver the same SQ like the built-In one? Does the device unfold MQA in the same way as with the built-in one?
Apr 24, 2021 at 12:41 PM Post #1,476 of 1,572
^^ Like most things audiophile, currently under debate. When you can, listen for yourself and decide.
I, for some reason, find a slight softness with the Tidal app and more detail in the open service, but that makes no logical sense, and I am mad at my brain for coming to this conclusion.
Apr 27, 2021 at 6:40 PM Post #1,479 of 1,572
Is this for music stored on the SD card? If so, is the SD card formatted in the FAT32 format as recommended in the user manual?
@JasonNYC So you are saying format in fat32 and not exfat?
Apr 27, 2021 at 11:40 PM Post #1,481 of 1,572
Yes, FAT32 is the recommended file format. If you format the card in the player itself, it will format as FAT32.
I did so and it's in process of reloading music. Going to take 8 hours to put all my music back on.
Apr 28, 2021 at 6:53 AM Post #1,482 of 1,572
Is there a way to stop it scanning SD card every time I turn it on. Takes 15 min to scan a 1tb card every time I turn it on.
Apr 28, 2021 at 1:16 PM Post #1,484 of 1,572
JasonNYC, please ask the developers to make the ability to remove music right in the player. I really lack this feature.
Not sure I understand what you are asking. Individual tracks and albums can be deleted from the player when viewing in Folder view. This option has always been available on AK players since the release of the AK100 in 2012.
May 6, 2021 at 11:17 AM Post #1,485 of 1,572
I wanted to report Apple Music is crashing right after App Start. Versions tried 3.4.5 and 3.5.0. AK SE Firmware 1.57
Tried to reinstall but no difference.
