Decided to take our hands at adding modifications to refine the sound of the SS. For the moment, all we did was contact enhancements at the connectors (both inside and out) and that it itself added considerable body to the depth of the soundn. The most effects were felt from the amp+player 4pin interface.
Curious to know which contact enhancement applicator you used so I can apply it to the outside of my player+amp 4-pin connection.
Mines been redwine modded so I've had the ribbon cable you see at the bottom replaced with copper litz wire on both the player and the amp sections. I always suspected that that was the cause of the increased amount of detail I was hearing after the mod since the rest of the redwine mod is basically caps to help with current delivery, e.g quicker, tighter bass with more depth. The increased amount of detail was probably the bottleneck of the ribbon cables being removed. Just my guess.
That ribbon cable is basically the interconnect between the player and the amp and when you combine the ribbon cable from the player section output and the amp section input, it's probably 2-3 inches.
Any chance you have the skills to replace it with silver litz wire. Curious how much of a difference it would make over the copper litz I have.
