Dobrescu George
Reviewer: AudiophileHeaven
Wireless Your Sound System
Stream Your Audio Wirelessly
Add an A50+ Amplifier to your current home stereo system and Wifi network then stream your favorite audio without any compression over wifi and Airplay.50W x 2 Powerful Output
Get the peak output 50W*2 with 4ohm passive speakers and our 24V 4.15A certificated power supply. Hear and feel the powerful stereo sound around your room.
Customize your Favorite Tune
No matter you like pop, jazz or electronic music with heavy bass, A50+ amplifier support our DSP tuning tool ACPWorkbench which allows you to setup different EQ for left and right channel and other audio effect features.
Wireless your 2.1 System
Different form old A50 Amplifier, A50+ add sub out interface that allow you connect your active subwoofer to build your wireless 2.1 system.
Simple Whole House Audio Solution
After setup the units in the zones you want to stream music, you can use our user-friendly app to quickly sync or play different music simultaneously. Easy control by sliding and clicking.
Good Compatibility to your Exisiting System
A50+ amplifier have more useful interfaces including rca input, sub out, optical in which gives you more options to stream your exisiting home audio system. Like any passive speakers, active subwoofers, AV receivers and TVStream All Music you Like
Huge music resources supported like Spotify, Amazon Music, Tidal, Deezer, Qobuz, Internet Radio, iheart Radio, Napster etc. Other than online music, you also can play local music by NAS, USB storage where you have collected your favorite song for years.What's More
Package
Specification
USER INTERFACE & CONTROLS LED indicators White-WiFi & network mode: Flashing fast-device is booting Flashing slow- waiting for WiFi connection Solid- WiFi is connected Blue-Bluetooth mode: Flashing slow- waiting for Bluetooth connection Solid- Bluetooth is connected Green-Line in mode Red-USB mode Yellow-connect to PC Purple-Optical in mode Power Button Device on: Short press once: Switch input mode Long press once: Switch off Short press twice: Disconnect current WiFi connection and enter paring mode (WiFi mode); Disconnect current connected Bluetooth device (Bluetooth mode) Short press three times: Restore the factory settings Device off: Short press: Switch on PC iTunes/Musicbee/Foobar 2000 Remote Remote Control Available 4stream App Free iOS and Android App | AUDIO Music Format FLAC/MP3/AAC/AAC+ ALAC/APE/WAV Audio Decode Up to 24bit/192kHz Audio Output 44.1khz/16bits, CD quality Frequency Response 20Hz-20kHz THD+N 0.03%, @1kHz 50W+50W 24V-4Ω Speaker Impedance 4-8Ω Speaker Power 2×50-W into a 4-Ω BTL Load at 21 V 2×30-W into a 8-Ω BTL Load at 24 Online Music Service Check here Local Storage Mobile device memory, NAS, USB pen drive/Stick | GENERAL Weight 0.5kg Dimensions 114.7*107.5*37mm Working temperature 0~40℃ Package Included Main unit x1 Antenna x2 User's manual x1 2-1RCA cables x1 2-2RCA cables x1 Remote cotrol x1 Screw Driver x1 Phoenix Connector x1 24V/4.16A DC Power adapter x1 |
CONNECTIVITY Wifi IEEE 802.11 b/g/n 2.4G Bluetooth 5.0 SBC/AAC, 10M Wired Connection Ethernet RJ45 Streaming Protocols AirPlay, DLNA, UPnP, Spotify connect, Qplay | INTERFACES DC Input 12V-24V Audio Input RCA Analog Input x1(2Vms) Micro USB Input x1 Optical Input x1 Audio output Sub Out x1(2Vms) Speaker output x1 USB Host For USB pen drive/stick, 1000 songs limited Antennas WiFi/Bluetooth Signal |
I copied all of that from Arylic's page. They make really cheapo but good streamers / AMPs / products.
I figured some folks may want to know that even if your budget is peanuts you can still power your speakers. A proper speaker powered from this A50 sounds much better than an Edifier S1000DB, which is a really popular model for the entry-level music lovers now, so I figured I should share news about the alternatives
More info to come ~
