Thats a lot of tubes to roll through in a short time. You must be listening full time
I am setting here basically disabled from a work injury for almost 4 years now and can not listen that much. Perhaps it is the Mogwai sounds to good to shut off
To be honest, I use a couple of fairly objective tests at the start that can taint my impression of a tube. If I tap lightly on the amp and can hear microphonics, the tube better blow me away or I eliminate it from contention. That nuked the 6550s from orbit immediately (super microphonic) as well as the Mullard KT88 and to a lesser extent the Electro-Harmonix KT88.
The 6550s are too bright in the upper mids. I investigated and that seems to be common among 6550 tubes. So I just bailed on that tube type entirely.
EL34 from reading sounds like they lose out on bass (and treble), which meant I didn't bother trying any of those. Except I kinda did below.
6CA7 is similarly soft sounding, so that got eliminated fairly quickly (though I'm keeping those tubes as a backup because they're solid). Pretty warm and romantic, but not very engaging.
The Mullard KT88 sounding kinda boring to me. I let them warm up for 30 minutes before listening (same with all the tubes). Their bass wasn't as powerful as reputed and they sounded pretty meh overall.
The Electro-Harmonix KT88 sounded good but were a bit microphonic. Nice extension on both ends, overall a very good sound.
The JJ KT88 sound quite good with fairly powerful bass. They sound nearly the same to me as the Electro-Harmonix with the added bonus that they are not microphonic at all. I can drum on the table and not pick anything up.
I have some tracks that have relatively harsh upper midrange that also lets me see if I cringe. If I do, the tube is gone. That happened when I rolled in the Russian input tube, which made me sad because they look so badass and are built like tanks. I'll eventually try burning one of those in to see if it smooths out.
I haven't done much listening to the various input tubes yet. I decided to try to focus on the power tubes first. The input tubes I do have all seem fairly similar in their impact on sound apart from the Russian tube.
