tdockweiler
I am Considering Upgrading From the Q701s to K712s for Better Low End Sound:
Should I just replace my headphone amp and keep my Q701s?
After all, the low end on the Q701s is affected by the amp which is driving them. I'm currently driving them via my Audio GD NFB-15, which is a beautiful sounding amp – but something about the synergy between it and the Q701s means there is a lack of low end in the sound. When I plugged the Q701s into my Cambridge Stereo Integrated 550a to see if this would make any difference to the low end, I discovered it did. Great bass, shame about the rest of the sound.
I'm pretty happy with my Q701s – however I am looking for depth and bass.
I am therefore looking for a solution where I can obtain a sound with more low end... but I am not willing to mod the headphones.
I'm looking at alternative solutions, and some advice in regards to which might be best:
> To change the amp to one that has a better synergy to the Q701s? Synergy definitely makes a difference – paired with my Cambridge 550a amp, they create a really good low end. I've heard the iFI iCan is a good headphone amp for added bass on the Q701s. Another option might be to use the Schitt Lyr with some appropriate Tubes. If a new amp is the best way to go, could anyone advise or suggest the best amp(s) to boost the Q701s?
> Or perhaps I should get a new pair of headphones? The K712s have a great low end and may offer a better solution... However, I am concerned that because of the 3db bass increase offered by these headphones, I might loose the neutral sound that I have with the Q701s. Does the 3db bass increase make the K712 less neutral?
Don't buy a new amp expecting extra bass. Any amp that magically adds extra bass is probably a piece of junk and not worth using. Unless it has a built in bass boost like the ican.
Without a bass boost, I doubt the M-Stage or any other solid state amp would give you the bass you're looking for.
The K712's are actually probably MORE neutral than the stock Q701s. I don't think I could call the Q701's bass really neutral, but close. Not really lacking too badly.
One idea is to just buy some K712 pads. They're pricy, but might give you a little extra bass. They just twist on and on easily. You can call the AKG parts department. Better than buying a new amp or headphone.
You should just force yourself to try the bass port mod and be done with it. It's not hard at all and I know you said you don't want to do that.
