MRC001
- Mar 20, 2014
Also, is it safe to assume that headphones have varying efficiency at different frequencies? Would this explain why planars seem to sound more full with more power? I.e. that a more powerful amp can handle less efficiency at lower frequencies?
Some headphones do, but the LCD-2 do not. If a headphone has flat frequency response it means its sensitivity is the same at all frequencies. But its efficiency might not be the same at all frequencies - it might not have a flat impedance curve. However, orthos (including the LCD-2) do have a flat impedance curve, so their efficiency curve has the same shape as their sensitivity curve.
Consider the LCD-2: it has flat impedance vs. frequency and also has flat sensitivity vs. frequency. Thus it should require the same power to produce any frequency at the same level.
