DefQon
- Jan 14, 2011
haha you called it THE amp for the LCD 2's. I said I am not sure if its THE amp but its very very good.
Indeed, my mjolnir has some tube characteristics while having transparency of solid states. It's all a matter of preference and synergy really.
The gungnir is not an amp btw. I don't if you were referring it as a amp given that you've listed only amps.
Ya sorry I mean Mjolnir. Ya it is a fantastic sounding amp but I think the DIY stuff which is a lot cheaper competes with it or surpasses it. On the down side though you have to spend many many hours building it yourself.
Dont mean to put you on the spot, but Id really like to know.
totally agree, soloist and lcd-2 is a great match (esp if you buy in Australia - the Mjolnir is over $1000 down under and got the soloist for under $800). got my soloist 2 days ago and it does a very decent job running the lcd-2. now the search is for a decent dac. any views on the nad m51.
MacedonianHero - macedonian folk music sounds so good on the lcd-2.2
Ok so Mjolnir vs my current M^3! Bifrost Uber vs D18. I can get a Yulong D18 and Mjolnir for $1000.
I would give the edge to the Mjolnir and the D18 but unless someone is giving them away I don't think you get get both for $1000. The Mjolnir is at least $600 used and the D18 I haven't seen it lower than $600 as well.
I think the Beta 22 competes with it. If you are into DIY than you can get the parts for a 2 channel beta 22 for about $400 for a very cheap version of it. But of course that cost doesn't include labor.
It was a offer I got from a friend. But at the same time if I return my Bifrost Uber, then that's $428 back, but then I'd have to sell the M^3. I'd be lucky if I get $500 for it since that's what I paid. Even then unless it's a good upgrade I lose around $100. I was also talking to him about $1060 for a Silver Balanced LCD-2 cable, and one balanced shielded interconnect to connect the DAC and Mjolnir together.
2 channel b22 for $400? Yeah sure you can it will probably burn your house down in the process. A properly built B22 2 channel configuration base parts will be around $400-450 including a basic 50va trafo for the o22 psu, price does not include case/enclosure/jacks/shipping.
You'd be looking at $500+ and assuming you already have some parts on hand and a very cheap crappy enclosure.
