I found that the Zilog dev kit (Z8F64200100KITG) isn't that expensive and can be found at mouser for 34,56€, I was thinking of getting it later and learn it when i have the time. However I know absolutely nothing about coding in C so it would be better if someone more experienced looked at it.
And on to what i have been doing!
After tracing paths on the pod pcb and measuring points for hours many "what if's" popped up in my head but one struck me hard, what if i could bypass the CS494003 for the front speakers and keep input, volume, sub, surround control and dts decoding on the pod?
I decided to sacrifice the analog input on the side of the pod as i never use it. I desoldered the closest smd resistor opening the circuit and connected the pad to one input of the opamp responsible for the front speakers.
Picture:
http://i.imgur.com/K1f8vAL.jpg
The result of this was incredible, there is no frequency cut at all and the sub still works with bass redirection and surround on and front speakers set to full-range running 6 channel direct. However volume control for fronts only works from 50% and up on the pod and as I haven't changed the caps for this opamp or even the opamp yet I thought i heard some crunching on higher volume. So I got another idea!
I soldered the first resistor back and removed the last resistor for the side input and then connected it after the opamp just before the NJW1150, I also connected the other channel.
Picture:
http://i.imgur.com/W8Z0D5Y.jpg
Backside:
http://i.imgur.com/65dA51t.jpg
The result? Simply amazing, you have no idea what this system is capable of until you try this!
The amp board has the great "third mod" as seen on ramachandras last pic in the guide since i bought it from him, this brings out the true potential of the mod and the sound is simply awesome. It now sounds better than very expensive audiophile systems i have heard.I have a pair of Marantz HD680 (8ohm 100w max) connected to the z-5500 and it sounds truly beautiful.
Are you thinking that the Marantz speakers is a waste on the z-5500 and it won't be able to push them? WRONG! The z-5500 speakers is actually very powerful, it has no problems at all pushing the speakers to their limit. The bass in the fronts kicks so hard I don't even have to turn on the sub!
Now there is not only good things that come with this mod and these are the minuses I currently know about:
- Volume control for front speakers only work from 50% and up. under that you'll have to lower on your computer. Apparently either the CS494003 or CS42526 adjusts volume from 1-50%, can't help to wonder why they did it like that. :/
- Front speakers will ONLY work with the side input regardless of what input you choose, even the analog in on the back is muted. (I don't know why but I'm trying to find a solution to this)
- Changing effects on the pod will not affect the fronts.
- DTS/DD won't work on the front speakers.
The best would be to access the Zilog and alter the CS494003 settings however if you can live with the above setbacks I can't help but recommend it until we gain access to the Z8.
I do NOT recommend doing this if you use digital and use DTS/DD as it will not work!
If you try this mod, be careful as you do it on your own risk! I'm not responsible if you mess something up. And be sure to turn the speakers OFF when connecting/disconnecting your cable to the side input, or you may damage your speakers!
