thelonious58
- Dec 25, 2014
Can Fiio X3 2nd Gen drive K601 or K612 decent enough? I've seen several posts here about E10K drives them perfect. After that I looked for the specs of E10K and it's so similar to X3 2nd Gen. What do you think?
A quick note: Since those headphones are not portable and open-back, I will use them generally with my computer. So X3 2nd Gen will be USB DAC for this case.
Specifications: http://www.fiio.net/en/products/39/parameters
Have a look at post #9269 from 13 days ago in the thread " Fiio x3 2nd gen" portable gear, it looks like the x3ii will drive most high impedance cans. Even my little Topping Nx-1 will drive them adequately on high gain from my iPod classic's LO . Fingers crossed! If the above post doesn't fully convince you, ask Brooko, because he knows the x3ii like the back of his hand and has also used the K612
