a1leyez0nm3
- Nov 4, 2001
well i tried my AH with 3 of my pcdps and so far i think that the AH isnt a $120 dollar improvement in sound....
i used:
1990 D-11 sony pcdp
1995? D-E301 sony pcdp
2001 Rio 250 pcdp
all had no eqs touched, etc...
i used a new trance CD with good bass highs all the waht not.
the out of the rio had a bit of static to it, but not bad. the D-11 sounded pretty good, and the 301 seemed a little dry sounding (little light on bass)?, with the D11 souding the best. i only listened to each for a short while, but this is how it seems
the headphone outs all sounded pretty good, with the d11 the best. the 301 sounded pretty good, but lacking bass and something else.... not sure... treble rolled off a bit maybe, and the 250 was a little loose in the bass a bit and scratchy, but they were all close to the AH...... very close....... in fact the differences seemed very slight, but most prominent on the 301 maybe. iduno... i tested it with very good sounding pcdps, so the differences were hard to tell apart, but the most outstanding one was the very slight scratchyness on the rio... but i get used to it after a short while and it becomes almost unoticable after a while.
i used:
1990 D-11 sony pcdp
2001 Rio 250 pcdp
