ROSSINL
- Jul 2, 2010
Hi,
I'm pretty new to using headphones for listening to music, but a few weeks ago I decided to purchase a Sennheiser HD 650 so that I can also listen to music in hi-fi during the late hours.
I already had a Asus Xonar Essence STX soundcard with dedicated headphone amp built in (TI 6120A2), so I thought this combination would give me spectacular sound. Although I am very pleased about the mids and highs of the HD 650, I find the bass quite weak and the bass extension goes not as deep as I hoped for.
So my question is: will buying a dedicated external headamp improve sound quality and will the bass go lower with more punch? I listen to all sorts of music, ranging from trance/dance to hiphop and from hardstyle to jazz music, mostly in flac or 320k/bit mp3. As a reference, I own a Klipsch THX Ultra II 7.2 setup and the subwoofers of this set are phenomenal. For example, when I listen to Chris Botti Live with Orchestra and Special Guests in Blu-ray, Billy Kilson's bass drum sounds nowhere as deep and detailed on the HD 650 compared to with my Klipsch set. Especially since I'm such a basslover, this disappoints me somewhat.
This is even with +20dB gain on the 30Hz band and +15dB on the 60Hz band using the equalizer in the Xonar software...
Does anyone own a HD 650 in combination with an Essence STX and found the bass to become better after buying an external headamp? I have the Meier Corda SWING in mind, anyone who also has this combination (or other Corda models)? And do you guys add bass to the HD 650 by using an equalizer? Because honestly, I don't understand how some people can call this a bass-heavy headphone without any adjustments..but again, maybe it's just me.
If low-frequency extension cannot be improved by adding a headamp, I guess I'll have to search for a more bass-heavy headphone. Any suggestions are welcomed..
Yesterday, I emailed Dr. Meier himself and he said that the problem with using a computer for playing music is the digital volume: when you lower digital volume, the audio resolution decreases to <16 bit. He said that when I buy a headamp I should maximize digital volume and adjust the volume only on the headamp.
In order to minimize the email burden on Jan Meier, can anyone please elaborate on this and advice me how I should best adjust the volume settings on my pc? I use VLC or MPC-HC player, so should I maximize their volume levels? With VLC, you can even set preamp levels to +20dB under equalizer settings, should I do this or set it at 0? And what about general Windows 7 volume, also at maximum?
Thank you for any help!
