Nostoi
Very tasty, indeed. I see you're rocking the rare out-of-print Brise IC...nice!Amazing combo...
Nice setup! I have heard the SR-001 once. It's pretty sweetNot bad too)
oh you've got a hifiman hm901r interesting! can you compare the two?After many years, the mission was accomplished and the king was found, now he lives in good company
901 with an iem or balance card is no worse than ar m2, it's just different, the disadvantage is the inconvenient software, and the advantage of Bluetooth ldac compatible is that I most often use it as a wireless dongle for streaming. ar m2 is more powerful and has an analog sound. 901 is multi-bit cirrus logic in terms of its sound, that is, it does not have an emphasis on any part of the range, and also has good attacks, while hifiman’s high range have a better sound, the scene is similar to aroh you've got a hifiman hm901r interesting! can you compare the two?
very interesting, it is more or less what i expected, thank you!901 with an iem or balance card is no worse than ar m2, it's just different, the disadvantage is the inconvenient software, and the advantage of Bluetooth ldac compatible is that I most often use it as a wireless dongle for streaming. ar m2 is more powerful and has an analog sound. 901 is multi-bit cirrus logic in terms of its sound, that is, it does not have an emphasis on any part of the range, and also has good attacks, while hifiman’s high range have a better sound, the scene is similar to ar
I can't say what's "normal" but on the pair I've had for a little over a month I get about 5 hours of music from full charge.Please tell me what is the normal play time from the battery in the ar-m2?
Show us the back, my friend. What's that engraving look like?Here are a couple pics from the only protective case I could find, the same on that people mentioned earlier in the thread, the one from a Chinese eBay seller. Dark green, with ‘AR-M2’ engraved on the back.
Here it is! I considered putting my name, but if I ever sell this I doubt someone is going to want my name on the case. Not that selling seems likely…Show us the back, my friend. What's that engraving look like?
