Maybe only on AE?
Sadly my agent only carry over items from TaoBao, nevermind, thanks for the suggestion anyways.
Maybe only on AE?
https://m.intl.taobao.com/detail/detail.html?id=13866284771Sadly my agent only carry over items from TaoBao, nevermind, thanks for the suggestion anyways.
Version with mic have Y cable, check it
Eh, I think that 150 ohm is too much, but I should've say it before. Are the Seahf 32 similar?Imo Seahf 150 is really good for metal, V Shaped with a very energetic sound. Kind of sharp sound. good for fast guitars and drums. And the price is low. However 150 ohm so you need a bit more juice than phone for it.
ty 32 quite thin sounding but very fast and crunchy for metal. More amping wouldn't hurt. Makes it better.Eh, I think that 150 ohm is too much, but I should've say it before. Are the Seahf 32 similar?
So less bass and less highs? Well, I don't mind trading the perfect sinergy for a more balanced sound. Thank you for your patience btw.i think Seahf 32 is different, have more balanced sound sig, a budget all rounder... it will be OK but not the best synergy
Don't know what else to suggest sorry
Thank you, but thin sounding is a no in my book, I prefer a beefy sound to a thin one.ty 32 quite thin sounding but very fast and crunchy for metal. More amping wouldn't hurt. Makes it better.
I don't believe recabling changes the sound either, but I don't like that cable very much, it looks fragile.@Qualcheduno Don't let people make you think in order for the Vido to be decent you have to replace the cable, because stock it sounds great. It just apparently gets better with recable, then again there are those that believe recabling produces no noticeable changes. It's up to you to decide which camp you're in.
