Lorspeaker
- Nov 29, 2010
http://pacifictv.ca/pixs/eiatubecodelist.pdf
a list of the brand codes
Any thoughts on the Sophia 6SN7 vs the CV181-Z Shuguang Treasures for a WA22? I'm running CV181-Z with Tung-Sol 7236 and Sophia Princess mesh plate. I got my BTs from http://www.ebay.com/itm/220860592075?_trksid=p2059210.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT but I'm intrigued by the Sophia 6SN7s. I know the Brimars are generally held in higher regards, but I'm not interested in those.
The Sophia 6SN7 is great on the WA22. There are surely NOS tubes for the same price that are just as good, but like to feel I'm supporting a modern tube producer who's quickly figuring out how to match the old stuff in quality. Because eventually the old stuff will run out...
Curious about this tube 6SJ7GT Sylvania
Very nice looking tube. No idea what it sounds like tho. Or if it works as a driver tube in a 6SN7 amp.
I seriously want to dull down my amp. I should explain a bit better. I want to roll of the treble. A lot. I'm not a fan of high treble.
I don't really want to effect soundstage, mid range or bass.
If I was going to do this what top 3 6SN7 type tubes would members recommend?
Please give me ya top 3 rolled or lazy treble tubes?
Dono
Just curious - do you have a rough idea how many hours you have on your (new) amp?
Reason I ask is that amps tend to mellow out significantly in the first 100 to 150 hours in my (limited) experience. If you haven't clocked at least that much runtime on your amp I would suggest waiting a while - you might be trying to fix a problem that goes away by itself.
Yeah, I get what you are saying. My amp and tubes are very very young.
However I cringe. Treble is so high. I am very sensitive to treble. The whole system would have to drop 30% for my taste and I can't see it doing that.
So I would rather have a list of tubes to hunt down now and get early so I can start breaking them in.
Badas, you need to use software EQ if you need to drop the treble by that much. Good amps and good tubes are specifically designed not to do what you're asking.
Yeah, I can't do that. I'm not using a computer. iPod and Oppo Blu-ray player for CD/SACD/DVD Audio only.
