reg66
- Oct 9, 2016
So my tube, the 1975 Reflector above, arrived today from ebay. All is well apart from the tube has a ringing in the right channel with the slightest touch of any of the surrounding things in close proximity. Even my amp (Lyr 3) has a cut off until the tube has warmed up for around 45 secs, after the 45 sec warm up time even the relay(?) clicking the tube sound on causes it to ring in the left channel.
Being a noob to tubes, does this mean the tube has A. had a knock, B. on its way out - EOL, or could it be as simple as C. that the tube just needs time to burn in?
The tube was advertised as NOS, but no returns. Going to look for a local business that has a tester at the weekend to test the tube but would like opinions in the mean time from you guys in the know about these things.
I have a Ken Rad VT231 that rang on the right channel when touching anything close by, but that also had an audible hum intermittently in same channel. My father reckons it could be because it's on its way out. Is it the same case with the ringing mentioned above - that the tube is dying? The ringing clears after a few seconds each time its present. But even pausing loudish music causes it to ring for a few seconds also. There is no deep hum like the Ken Rad, but the reflector does ring like a chime if you tap it super gently whilst on (left channel only).
Any help is much appreciated
