You're going to build my design? Or you're going to build a similar multi-5532 design? Either way, I'll do anything to help that I can.
I have lots of headphone amplifiers that I have designed. I don't listen to this one very frequently, but I remember the sound as highly satisfactory with the phones I was using at the time. The first thing I do with an amp when I build it (other than checking for fatal errors) is listen to it, kind of obviously, but critically, for problems. Hiss, crackle, distortion, flatness. Is the gain appropriate? Do the channels match? Is there any noise when the controls are operated? Are pops at switch-on and -off suppressed? When I've done that, though, I don't analyse the sound any further, other than notice problems if they should arise. I'm not really seeking some holy grail, I'm more seeking to create a finished product or range of features, but with essentially transparent performance. This amp let me test some digital stuff, it was quirky, and it wasn't expensive to put together. The feature here is that both channels can be adjusted in half-dB steps. Of course it can be built fully analog.
In common with other of my designs, I have numerous schematic variations. If I have a new idea, I rename the schematic rather than discarding. The nature of CAD is that if the schematic is correct, then the connectivity on the board is generally (although not absolutely always) correct. This enables me to evolve layouts. This does mean, however, that component values may sometimes not be shown correctly, as I always have the option of changing a value as I place the component.
I do have some recent tweaks I would regard as desirable to include.
Keep us posted with your progress or let me know if I can do anything.
Fred
