chesebert
18 Years An Extra-Hardcore Head-Fi'er
- May 17, 2004
Originally Posted by mark_h /img/forum/go_quote.gif Writes in sleep...trust your ears, ignore sound science...zzzzzzz |
Originally Posted by gregorio /img/forum/go_quote.gif It's not just me, many, many others have respect for one of the leading experts on the planet. I realise this counts for nothing here on head-fi though, where everyone appears to know more than those who do it for a living or indeed know more than the leading experts. Of course, it's not just the ability to process the datastream but also the fact that there is nothing in those frequencies to capture. There has been arguments that audiophiles here on head-fi can apparently hear beyond 20kHz and are therefore different from normal human beings. Are we now going to have a discussion that head-fiers can now hear beyond 48kHz and need the frequency of digital audio to go up to 96kHz? If so you are wasting your time, no microphone in any recording studio goes anywhere near 96kHz, in fact very few of them go much beyond 20kHz, what about your speakers or cans, do they have a freq response of 96kHz? Anyone thinking there is anything that can either be captured or heard up there is completely fooling themselves. Just to make it clear, there could (in theory) be some benefit to 96kFs/s under certain conditions. 192kFs/s is a complete waste of time, it's even a waste of time for recording, let alone for listening. G |
Originally Posted by Acix /img/forum/go_quote.gif Maybe you're the one that's fooling yourself, here. There are professional studio monitors like the Adam and the Yamaha that go up to 35-40kHz. The thing is, you don't have to be able to hear up to 40kHz in order to perceive the information there. And of course, this knowledge is proven through lab equipment that measures the frequencies. Now practically, in the studio, these headphones and speakers that have an extended frequency response will have more space to the sound and therefore the music will be more, precise, smooth, airy and dynamic with a better details in the image. This is sound resolution and it's the same with digital. You don't need to be able to hear up tp 96 or 192 kHz, but there is information that is stored there. Of course you need to work with a chain of studio equipment that supports high resolution. Eventually when you're going to dither down to 16/44, or just a lousy mp, your mix will be much more rich and this is the benefit of working in high resolution. |
Originally Posted by JaZZ /img/forum/go_quote.gif Maybe -- but you can't be sure about that. Not more sure than other -- knowledgeable -- people. Or people with positive experience with 192 kHz.. |
Originally Posted by gregorio /img/forum/go_quote.gif This is not just an opinion, it's very simple fact. No instrument produces any notes beyond about 8kHz, the only thing present anywhere near 20kHz is harmonics. Each subsequent higher harmonic is lower in amplitude than the previous harmonic. |
This is simple basic acoustics. By the time we get to around 20kHz the harmonics are so quiet that they are starting to disappear below the noise floor. |
Just to make absolutely clear, there is nothing produced by any instrument that exists above the noise floor once we get to about 30kHz |
Originally Posted by linuxworks /img/forum/go_quote.gif so, suppose you have 2 high freq waves that are at slightly diff frequencies. combine them on a scope and look at the places where they overlap - you need higher frequency components needed to be able to reproduce that, don't you? |
Originally Posted by nick_charles /img/forum/go_quote.gif That is not strictly true. The pattern is not linear , it tends downwards but some harmonics are higher than their predecessors. That depends on which noise floor you are talking about. With CD the noise floor at -96db is low enough for harmonics at 20khz to be comfortably above the noise floor and in the cymbals crash test I did when the fundamental was at -5db the high harmonics were at ~ -63db at 20khz. Now I cannot hear that and you would need a quiet hall to get them but it is far from implausible and in a quiet listening room no problem. What renders them moot is masking, if you have a signal at -5db and one at -60db the one at -60db is not going to get noticed very much. Um, the Balinese Gamelan has harmonics above the noise floor extending way up beyond human audibility. |
This is not just an opinion, it's very simple fact. No instrument produces any notes beyond about 8kHz, the only thing present anywhere near 20kHz is harmonics. Each subsequent higher harmonic is lower in amplitude than the previous harmonic. Quote:
This is simple basic acoustics. By the time we get to around 20kHz the harmonics are so quiet that they are starting to disappear below the noise floor. Quote:
Just to make absolutely clear, there is nothing produced by any instrument that exists above the noise floor once we get to about 30kHz Quote:
Originally Posted by gregorio /img/forum/go_quote.gif I was not referring to the the theoretical noise floor of CD but to the actual noise floor when recording or replaying the signal and the actual practicalities of the equipment. |
So although there are the odd instruments (like Gamelan and some cymbals) which do produce harmonics above the theoretical noise floor of digital audio, they are not above the noise floor of the practical equipment or environment (including Brownian motion) in a recording and playback chain. |
Originally Posted by gregorio /img/forum/go_quote.gif If there is nothing there to record, if none of the equipment is capable of recording freqs in that range and if none of the playback equipment is capable of reproducing it then, yes I can be sure. Look, it's quite simple. No microphone can pick up anything much beyond 20kHz, yes some of their specs go to 35 or 40kHz but just look at the response roll-off. If there was anything up there, mics cannot record it. |
Secondly, yes, there are speakers that will in theory go up to 40kHz but what are they going to reproduce, nothing can be recorded there and you couldn't hear it if it were. Of course 40kHz can (in theory) be recorded using a sample rate of 96kFs/s. So now you want to double this sampling rate to 192kFs/s so your audio limit is now 96kHz. 96kHz is more than double what can either be recorded or that your system can reproduce. |
This is not just an opinion, it's very simple fact. If people think 192kFs/s sounds better, I'm sorry but there is no sensible alternative to the fact they are fooling themselves. The only possible alternative is that their DAC has some kind of malfunction which so negatively affects the re-construction of signals at 44.1kFs/s and 96kFs/s that 192kFs/s sounds better. It really is just another case of consumers' expectation that more data = better quality. |
Just to make absolutely clear, there is nothing produced by any instrument that exists above the noise floor once we get to about 30kHz and there is certainly nothing at 96kHz. Even if there were, it is not possible to record it because it is way beyond the capability of studio mics. Even if something does exist and we could record it, your system could not reproduce it and even if it could, it's well beyond the hearing capabilities of a dog, let alone a human being! Remember also, there is no reliable proof that anyone can hear beyond 22kHz... |
Originally Posted by nick_charles /img/forum/go_quote.gif No, these are separate issues and I do not disagree with you on the pragmatics, but to say something is below the noise floor you now have to say what the noise floor is. If it is -50db then Gamelan harmonics are in play What is the ball park noise floor for a decent acoustic recording set-up ?. The ~ 20K cymbals harmonics I recorded from a 16/44.1 sample played back on an average CD player and recorded on a low end ADC were 30db above CD noise floor which is a lot , they may be above recording room noise floor ?. In the Oohashi study the Gamelan had harmonics at 50khz that were at -50db wrt the dominant tone and harmonics at 20K that were much much higher. The Oohashi study is highly flawed but I do not doubt that part. |
Originally Posted by gregorio /img/forum/go_quote.gif If there is nothing there to record, if none of the equipment is capable of recording freqs in that range and if none of the playback equipment is capable of reproducing it then, yes I can be sure. Look, it's quite simple. No microphone can pick up anything much beyond 20kHz, yes some of their specs go to 35 or 40kHz but just look at the response roll-off. If there was anything up there, mics cannot record it. Secondly, yes, there are speakers that will in theory go up to 40kHz but what are they going to reproduce, nothing can be recorded there and you couldn't hear it if it were. Of course 40kHz can (in theory) be recorded using a sample rate of 96kFs/s. So now you want to double this sampling rate to 192kFs/s so your audio limit is now 96kHz. 96kHz is more than double what can either be recorded or that your system can reproduce. This is not just an opinion, it's very simple fact. No instrument produces any notes beyond about 8kHz, the only thing present anywhere near 20kHz is harmonics. Each subsequent higher harmonic is lower in amplitude than the previous harmonic. This is simple basic acoustics. By the time we get to around 20kHz the harmonics are so quiet that they are starting to disappear below the noise floor. By the time we get to 30kHz the harmonics are already way below the noise floor. Even the finest mics have very little response at 30kHz (let alone able to record something below the noise floor), so there is simply no physical way to record these harmonics. If there is something stored in these ultra-sonic frequencies it can only be system noise generated by electronics in the signal chain. If people think 192kFs/s sounds better, I'm sorry but there is no sensible alternative to the fact they are fooling themselves. The only possible alternative is that their DAC has some kind of malfunction which so negatively affects the re-construction of signals at 44.1kFs/s and 96kFs/s that 192kFs/s sounds better. It really is just another case of consumers' expectation that more data = better quality. Just to make absolutely clear, there is nothing produced by any instrument that exists above the noise floor once we get to about 30kHz and there is certainly nothing at 96kHz. Even if there were, it is not possible to record it because it is way beyond the capability of studio mics. Even if something does exist and we could record it, your system could not reproduce it and even if it could, it's well beyond the hearing capabilities of a dog, let alone a human being! Remember also, there is no reliable proof that anyone can hear beyond 22kHz and we are talking here (with 192kFs/s) about extending the range of encodable frequencies from 48kHz to 96kHz! Lastly, in answer to the last sentence I quoted from Acix: If you decimate the sample rate from 192kFs/s to 44.1kFs/s a brickwall filter has to be applied to completely remove all audio frequencies above 22,050Hz. If all the frequencies above this point are not removed the re-sampling fails! So whatever may or may not be above 22kHz is totally and permanently removed. If there is nothing there, it cannot therefore make the CD sound "rich". G. |
Originally Posted by Acix /img/forum/go_quote.gif If you want some reliable proof that anyone can hear beyond 22kHz. You can check out the SPL Phonitor...I was able to listen to the Phonitor and compare my previous Ultrasone PL650 to the K702. Check it out if you get a chance, you just might be able to hear something above the normal human range. If not, you can still hang on to your theory. Now, I get the impression that you don't really have experience working in HR sound environment...just theoretical concepts. Even for a theoretical concept dude whose beliefs are stronger than his experiences, you still believe that the leading expert at ADAM and Yamaha and SPL and all the other manufacturers have just created this range out of thin air to use as a marketing tool. |
