2359glenn
Member of the Trade
- Aug 16, 2010
If the low-Z headphones are efficient, such as the TH-X00, the Glenn OTL will work well. If you wish to use inefficient low-Z headphones, such as HE-6, then a transformer-coupled amp, such as the Glenn EL3N or 300B would be preferable.
As Glenn voices his OTL with Senns, that is a match made in heaven.
OTL it is then, my Senns are my main headphones and will likely remain that way for some number of years.
Any recommendations for the upgrades? I was thinking of getting the Lundahl transformer upgrade, trying to look up impressions for it now.
If you want to use low-Z headphones the best upgrade is the 5998 mod when used with 6336 output tubes it lowers the output impedance.
