PurpleAngel
If I were to get Xonar DX and a Schiit Magni, I would have sufficient power for Q701's and Dolby headphone surround sound? What advantage does the Magni have over say a Fiio E9? How would surround transfer into the Schiit of the Fiio? I think I've decided...
EDIT: Would this card work for what I want? I found it cheap on craigslist.
http://www.amazon.com/Creative-SB1040-Sound-Blaster-Xtreme/dp/B000W7PNZI
The Magni should easily drive the 62-ohm Q701s and you will have Dolby Headphone surround sound with the Magni/Xonar combo.
Not a big difference to me between the Magni & E09K amps, I just recomend the Magni because of it's really low headphone output impedance, less then 1-Ohms (E09K is 10-Ohms), makes the Magni a little more desirable for use with lower impedance headphones, like under 50-Ohms.
The Creative Xtreme audio is not well liked among the Creative sound card owners.
I believe it uses an older Creative audio processor with updated drivers.
