Hello again everybody,
I would like to address something that maybe at times overlooked by some listeners. I am referring in this case to output impedance. It is extremely important that when choosing an iem one chooses the proper device to drive said unit. Output impedance of an amp, dac, or phone plays a big role on frequency response. Choosing the proper amp can make the difference of loving or hating the sound signature you end up hearing.
For those who say the A/U12 is very "veiled" and lacks detail with the S1 module I can with certainty say that you are probably listening to your A/U12's through a very low output impedance source. In the case of the A/U12 this gives more bottom end, higher low mids, and slightly dipped out high mids/highs. Remember though this depends on the design and tuning of the iem... believe it or not some iems behave the opposite way around when being driven with higher and lower output impedance sources. The A/U12 inherent design is such that mating them with a higher output impedance will give the proper "reference" frequency response. They will no longer be so bass heavy and have a much more transparent top end.
I would like to point out that some people prefer a darker and bass heavy sound... which can be very appealing with certain content as well as not fatiguing when listening at loud volumes. A CHORD Mojo would be a perfect amp/dac for those who enjoy that type of sound and own some A/U12's. Some people prefer a flatter "reference" sound signature... one that has more transparent high mids and highs and maybe not so much inflation in the low mids and mid bass. A higher output impedance amp/dac would achieve such results for those listeners.
I believe its very possible that many of you that say the A/U12's sound "veiled" and that the B1 module fixes the veiling issue are using a low output impedance amp/dac and are over compensating with a B1 module to bring down the bass and low mids. Thus balancing out the inherent response of the A/U12's through a low output impedance amp. For those who believe the A/U12 sounds "veiled" with the S1 module simply changing over to a source with a high output impedance will give you the desired sound signature... all without swapping modules.
Here is a comparison of the U12 through two different output sources. One with a low output impedance (CHORD Mojo). And one with a higher output impedance (USBPre 2). Notice the seesaw effect between switching from one source to the other. Forgive me if I sound redundant at times I just wanted to explain the effects of output impedance for everyone to understand. I hope this helps you guys achieve the sound signatures you search for
EDIT: I apologize, in the image it says the USBPre 2 is 30 ohm output impedance... It's actually 22 ohm. Excuse me for this minor mistake.
