Shanling M0 Pro - Ultra-Portable Hi-Fi Player, Now With Balanced Output!
May 17, 2024 at 2:49 AM Post #796 of 812
I'm having some encoding problems in the music tags:
The values should be:
Title: Canção de enga...
Artist: António Variações
Album: de António Variações
But in other album he can decode some special characters correctly:
In this example he decoded correctly the ó and the ã, but failed in the çã, the album should be A invenção do...
Any ideas what I can do to fix these tags?
Thank you.
Same problem with mine.
May 20, 2024 at 9:54 PM Post #800 of 812
Is the M0 pro bluetooth signal strongest and more stable than the M0, especialy in Aptx ?
M0 Pro has more advanced Bluetooth module and overall Bluetooth performance is better.
Can I use the shanling 4.4mm to 3.5mm balanced adapter, with a 3.5mm unbalanced?
No! Only use Balanced adapter with Balanced connection.
Thank you.
Noted, will report to software team, they need to adjust system/fonts for this.
May 26, 2024 at 10:09 PM Post #802 of 812
I’ve just recently got an M0 Pro after being a very happy original M0 user for the last six years. My M0 Pro has broken in and is sounding fantastic with a pair of NiceHCK F1 Pro planar magnetics that I’m using with Final Audio black type E ear tips that balance the treble nicely. It has improved on the original M0 with better imaging and more articulate bass.
I wonder if Shanling could release their own planar IEM that was tuned to go with the M0 Pro. I am knocked out by the combination of the tiny player and the planar sound of my NiceHCK F1 Pros that have good tone and timbre too.
I also have a 1.5tb micro SD card on order which was one reason for upgrading to the M0 Pro. I will be able to fit every CD and download I’ve obtained over the past 30 years in Apple Lossless - 3400 albums. I find it quite mind blowing to have a room full of CDs fitting in a device the size of a matchbox.
May 26, 2024 at 11:09 PM Post #803 of 812
currently 1.5tb SD card is undetected in latest firmware, shanling will address it soon hopefuly
May 26, 2024 at 11:10 PM Post #804 of 812
Ah ok, thanks for that - ill have wait for the new firmware
May 27, 2024 at 9:40 PM Post #805 of 812
My clip broke. Having a hard time getting the purchase approved at allipress. Why does Amazon or Ebay not gave them?
May 29, 2024 at 4:25 AM Post #806 of 812
Still the same problem with MQA files, the playback is choppy in the last firmware, it don't stop, just seems the player is struggle to play those files. I will just use Flac from now on.
May 29, 2024 at 4:40 AM Post #807 of 812
Shanling don't make any claims that the M0 Pro supports MQA do they? So it will just decode the files as normal PCM and ignore any special MQA bit patterns embedded in the data.
May 29, 2024 at 4:45 AM Post #808 of 812
I though I have read somewhere in the official product page that it supports MQA, but can't find it now. Anyway, I don't really care about MQA, but have a bunch of files :sweat_smile: will just get them in Flac.
May 29, 2024 at 4:59 AM Post #809 of 812
M0 Pro has no support for MQA files.
  • Back
