iBasso DX180 Got your music? Enjoy the concert! Released and ready to play.
May 6, 2024 at 9:03 AM Post #16 of 154
Does anyone know if the DX 180 replacing the DX170?
May 9, 2024 at 10:39 AM Post #17 of 154
removable battery? I guess I might save more money and buy this instead of Hiby R4. Not to mention the colours! Also the fact that Type-C and headphone jack is on the opposite site of the player.
I saw a pic on other site said it cost ¥2999 for 3GB of Ram and 32GB Storage and ¥3599 for 4+128GB
May 9, 2024 at 10:55 AM Post #18 of 154
May 21, 2024 at 1:51 AM Post #23 of 154
https://mp3tidalwave-ur.blog.jp/arc...8zCSHE-O1VsyQUPULTkkgvb8YemLicJQmOPPp_fTLPBBB
General parameters:
Model: DX180
Color: Dark Night Black, Pine Green, Meteor Blue
Body material: Aluminum alloy
Display: 5.0-inch IPS screen, 1080*1920 resolution, with on-cell capacitive touch screen
USB connection: Type-C USB 3.1 (high-speed data transmission and fast charging)
Output: 4.4mm balanced headphone output, 3.5mm single-ended headphone output; 4.4mm linear output; 3.5mm linear output; 3.5mm coaxial output
WiFi: 802.11b/g/n/ac (2.4Ghz/5Ghz)
Bluetooth: V5.0
Storage: 4G RAM + 128G ROM, 3G RAM + 32G ROM, expandable Mirco SD (TF) card slot
Battery: 3200mAh 3.8V lithium-ion polymer battery
Charging time: about 1.5 hours
Playing time: low-gain balanced output 15.5 hours, high-gain balanced output 13 hours, Line Out 30 hours (may increase or decrease due to different operating methods and sound sources)
Weight: 206g
Standard accessories: host/Type-C data cable/TPU protective case/screen protector/warranty card/quick guide
Audio indicators:
4.4mm balanced headphone output:
Output level: 4Vrms (Low Gain) 6Vrms (High Gain)
Output power: 690mW + 690mW@32ohm, distortion <0.1%
Frequency response: 10Hz~75kHz-1dB
Signal-to-noise ratio: 133dB
Dynamic range: 133dB
THD+N: -121dB (A-wt, 600ohm load)
Separation: -144dB
Impedance: 1.1ohm
3.5mm single-ended headphone output:
Output level: 2Vrms (Low Gain) 3Vrms (High Gain)
Output power: 281mW + 281mW@32ohm, distortion <0.1% 525mW + 525mW@16ohm, distortion <0.1%
Frequency response: 10Hz~75kHz-10 dB
Signal-to-noise ratio: 127dB
Dynamic range: 127dB
THD+N: -116dB (A-wt, 600ohm load)
Separation: -118dB
Impedance: 0.6ohm
May 28, 2024 at 3:58 AM Post #28 of 154
Interesting part that both new ibasso dx180 dap and ibasso dc07pro dongle will have 4XCS43131 DACs inside 🤔👍
This is a downside of niche markets. Manufacturers purchase DAC chips in bulk and then keep churning out new devices with the same chips until they run out of inventory. Only few brands are bold enough to adopt to the latest stuff as they are released and these brands are usually much more expensive (which I personally don’t mind).
