[FiiO K3/FiiO NEW K3]-HiFi Headphone/Desktop Amplifier,USB-C DAC featuring Type-C port,3.5mm LO ,3.5mm + 2.5mm headphone outputs,Coaxial and Optical digital outs,supports up to 384kHz/32bit PCM and native DSD256
Nov 26, 2018 at 5:10 AM Thread Starter Post #1 of 89
FiiO
Sponsor: FiiO
Guangzhou,China
FiiO's All-new Headphone Amplifier & USB-C DAC K3 will hit the market soon! -- Nov. 26
Boost your computer's sound with capable decoding
Equipped with an XMOS U30881C10 USB receiver chip, the K3 is capable of decoding up to 384kHz/32 bit PCM and native DSD256.
Nov 26, 2018 at 8:58 PM Post #2 of 89
Finest components for maximum potential
The combination of high-performance AKM AK4452 DAC with low-distortion op-amps OPA926x2 and professional-grade LPF TI OPA1612 ensures outstanding performance.
Nov 26, 2018 at 9:02 PM Post #3 of 89
FiiO's All-new Headphone Amplifier & USB-C DAC K3 will hit the market soon! -- Nov. 27
Modern USB Type-C input interface
The USB Type-C ensures a more reliable and stable connection. Moreover, the K3 implements overvoltage protection (OVP) and a double-filter circuit to ensure power supply stability.
Nov 26, 2018 at 9:03 PM Post #4 of 89
ADC volume control
The use of ADC volume control can not only eliminate channel volume imbalances, but also allows the user to smoothly adjust the volume to a more accurate and finer degree to boost headphones of all kinds of sensitivity for a variety of listening needs.
Nov 27, 2018 at 5:49 AM Post #6 of 89
Power supply is via USB.
Output power :
SE => 220mW into 16 ohms, 120 mW into 32 ohms
BAL => 320mW into 16 ohms, 200 mW into 32 ohms
Why the AK4452? Cheaper - and this is a more economical desktop product after all. Plus the levels of performance (considering what is actually audible) are on par with the AK4490 anyway. AK4490 has slightly better specs, but a lot more expensive, and you won't hear the improvement. Like a lot of things in audio - just because the numbers are larger does not necessarily make them better!
Oh - and it sounds pretty good too!
Nov 27, 2018 at 8:17 AM Post #7 of 89
Output power :
Thanks for reply, I was planning to buy Q1 MKII. Since my main use is not portability I can go for this instead, hopefully my local fiio dealer gets it quickly.
Nov 28, 2018 at 1:57 AM Post #9 of 89
High and low gain
The switch for high and low gain ensures that you can use the K3 with a wide variety of headphones, and that your listening volume needs are covered.
Nov 28, 2018 at 5:23 AM Post #10 of 89
My Motherboard has Optical, Can I connect the K3 to my Computer's Motherboard via Optical Cable?
The optical and coaxial on the K3 are digital output ports, then it can only directly converts USB audio input to digital signals output via the coaxial and optical connectors, allowing you to connect to speaker systems, amplifiers, or other external decoders.
Nov 28, 2018 at 5:42 AM Post #11 of 89
Bass boost switch
The hardware bass boost switch enhances the dynamic range of the lower frequencies and gives them some extra punch to really make your songs, games, and movies come to life.
Nov 29, 2018 at 5:59 AM Post #12 of 89
Tiny round goodness in the palm of your hand
The all-aluminum black body has been painstakingly CNC-machined, anodized, and sandblasted to ensure that the K3 feels robust yet perfectly textured for a great feel in your hands.
Nov 29, 2018 at 6:00 AM Post #13 of 89
A distinctly cohesive tactile audiovisual experience
The volume knob, with 45° notches etched onto its surface and perfectly sized to allow easy one-finger operation. Next to the volume knob is an RGB light that indicates what kind of digital audio is being input to the K3.
Nov 29, 2018 at 9:51 PM Post #15 of 89
When is this coming out? I'm thinking of buying an E10K but if this comes out soon I'll wait.
Sure you can kindly wait for the K3 since it's being delivered to worldwide sales agents now and we will announce the official release tomorrow.
