would you mind sharing more of your experience and thoughts? I’m especially curious about what other amps you’ve heard to compare/contrast assuming the rest of your system was the same.
Thank you.
Yes of course, thanks for asking. I've been thinking a lot about how to further express my enthusiasm for the Headtrip II. I don't think my earlier impressions really did it justice. As far as previous dynamic amps, I've owned both versions of Woo Audio's WA22, and a Schiit Ragnarok 2 among others. The sources I'm feeding into my preamp have been pretty constant lately, although I did recently upgrade the SACD player to the next level from the same manufacturer (Yamaha CD S1000 to S2100).
edit: For the more challenging headphones like the HE-6 and K1000, I used the WA22 to drive a variety of solid state speaker amps with varying degrees of success. These ranged the gamut, from pro audio amps to vintage receivers to, more recently, hifi monoblocks. Nothing like good tubes into SS amplification, IMHO.
The biggest difference in my system recently would have to be from changing my balanced tube preamp, from the WA22 to the SA3. They're both Woo Audio balanced transformer-coupled tube preamps. Some tubes are different (notably the power tubes are now 300b's), some are the same. Completely different headphone amp sections though. From the perspective of the Headtrip, I'm not sure I can tell a difference; if there is one it's really subtle. If anything, the 300b's are making the SA3 a bit noisier, but I've only take notice when using the headamp section (and really only while using my SR-009's, which are my more efficient electrostatic headphones). I'm still using stock 300b's in my WA3, but my WA22s were outfitted with premium tubes from years of rolling.
One factor that blows my mind is how I don't want to buy any more dynamic headphones anymore! There are so many new flagships out now, that I wanted to try them all. I bought the Abyss Phi TC first. They were at the top of my list, and are the latest version of the headphones the Headtrip was originally designed to drive. I love them, they are the best I've heard overall so no regrets there. But what I wasn't prepared for was how much it would improve my old standbys, many that I planned to sell.
I have a few other 'flagship' (mostly former) dynamic headphones. From one of the first LCD-2 models, to a couple iterations of the HE-6, to the Utopias and the Empyreans, a bass-heavy K1000, and a PS1000. There's also an Edition 8 and a Stellia and I might be forgetting something. Plus a few other non-flagship favorites I haven't been able to let go of yet either. I was planning on selling at least a few of these. But then something happened. I plugged my old headphones into my new amp and holy headtrip batman, this is a whole new ballgame. I love it when a single piece of equipment changes the entire audio equation.
All of my old dynamic headphones, to varying degrees, sound new to me through the Headtrip II. There's still a few I haven't tried yet. The most mind-blowing so far is the AKG K1000's. I thought I was driving them adequately out of my Rag 2, but I was mistaken. They really sing now, with tight articulated bass that I had no idea they were capable of. The PS1000 really tightened up as well. There were a couple of surprises, like how the Empyreans failed to scale up. This has happened before, when I went from a Mojo to a Hugo 2 with them. But the surprise was how the LCD-2's
did scale up, to the point where they were outperforming the Empyreans both technically and musically. I still like the Empyreans quite a bit, they are so easy to listen to and physically comfortable. I may still sell the Empys, but only to make room for Meze's new flagship.
What I like the most about the Headtrip II is how relaxed the sound is, while being so technically outstanding. It's not just the bass, but the midrange is more clear and the treble more relaxed. This part is the hardest to describe, but to me the headtrip really does have some liquid, tube-like qualities to it. Magical even. If I hadn't chose (really not a choice; just a seemingly simple option that went sideways) to cripple the RCA inputs on mine, I have no doubt that it would still sound great from a competent single-ended source, even without a preamp in between.
Jeff's idea of moving the power supply outboard was a success, as the stated goal of driving Utopias without any noise was achieved. It was actually surpassed, as I didn't notice any noise with Focal's more efficient Stellias either. I suppose the cutoff for noise is somewhere between the Stellias and the Edition 8s. With the latter, I heard a little noise when the music was paused, and just barely with the volume down. I think this means that, with the outboard power supply, the Headtrip II will now drive any full-size headphone without any noticeable noise.
I also had the pleasure of driving some top-notch IEMs, and while there was definitely some noise my Odins sounded better than ever when the music was playing. That was using a thicker than stock all-copper cable, a Bort II 4.4mm cable which may account for the increased depth I noticed to the overall sound, into a generic SPC 4-pin XLR to 4.4mm cable. Attenuation can be tricky with IEMs, but so far it's manageable. An adapter just arrived, so soon I will try it with the stock Odin 2.5mm cable.
I would love to see Jeff expand on the idea of an outboard PSU with a larger matching full chassis-width (but not height!) option, made for stacking. Room for all the bells and whistles like tubes, large capacitors and the like. It could be a great upgrade. Maybe it could even take the noise floor down another level for stuff like IEMs. Not a necessary option, but just to see how far the concept can be taken. I have no idea if it would improve the sound, but I'd probably buy one to find out.
