Holo Audio May DAC Speculation
May 1, 2024 at 7:04 AM Post #1,261 of 1,319
I've tried a number of so-called "perfect" USB devices. Many were good, none have offered complete immunity IME. I respect that may not be everyone's experience, hence my recommendation to test in your own system.
May 1, 2024 at 7:26 AM Post #1,262 of 1,319
Thanks everyone for the clarifications and advice. I haven't decided yet whether I'll use hqplayer with may. As I wrote earlier, I couldn’t find filters that I really liked. I'm waiting for May and will experiment.
I have a powerful PC with 13700 and 4090 rtx. But he is standing on the opposite side of the room. This is an 8 meter USB cable. Buying a second PC to use exclusively for hqplayer, and placing it next to May, is wasteful - I don’t know, I want to go this route. Now I use a regular 10m USB extension cable to connect my PC to the Hugo tt2. Everything works fine and hqplayer works through cuda on rtx 4090, which allows you to use it to the maximum.
Purchasing a streamer will allow you to connect hqplayer over the network. And from the streamer send a signal via usb/i2s to May.
These are my plans for now.
May 1, 2024 at 9:04 AM Post #1,263 of 1,319
Why not consider PGGB, which can remaster files offline to DSD1024, and sounds incredible? So remaster on that PC, then use them in your server near to the May.
https://www.remastero.com/guide-plus.html#QSDSD
PS, I used to own the May, and still have my Dave. Used it with DSD upsampling out of HQP but didn't like it, too smooth- so sold it. The new PGGB DSD has really changed my mind about DSD. Downside is, you kinda still need powerful PC to upsample them, so quite similar to HQP requirements.
May 1, 2024 at 9:12 AM Post #1,264 of 1,319
The problem is that I don't have my own music. I use streaming services exclusively.
May 1, 2024 at 10:11 AM Post #1,265 of 1,319
I don't know if I'm allowed to mention this but when I tried PGGB I simply used Qobuz-dl to rip the files from the streaming service.
May 1, 2024 at 10:41 AM Post #1,267 of 1,319
Is XLR or RCA preferred for the May? And does anyone have favorite cable brands they recommend ?_? I will need a new cable as my old one is too short.
May 1, 2024 at 11:06 AM Post #1,268 of 1,319
Definitely XLR. If you're sensitive to cable differences my recommendation is Lavricables Grand XLR which are expensive but not Audioquest levels.
If you're not get some star-quad configuration copper ones with Canare or Mogami wire and Neutrik plugs. (Benchmark sells quality ones for a low price)
May 4, 2024 at 12:49 PM Post #1,270 of 1,319
Pretty much as Goldensound said. I prefer tube amps and listen to R&B, Rock, dance, edm and the Rockna gave me everything the May did but with more impact. I could see why Holo designed their amp to be so punchy as it probably pairs so well with the May’s extremely smooth presentation. I needed a bit more bite because I mainly use the WA33.
holo amp as in Bliss?
Bliss is not punchy amp. Does everything well except for the punch.
May 7, 2024 at 2:30 PM Post #1,272 of 1,319
Hi guys... now I'm using the Termie Plus + Hermes DDC and good Coax cables to sync the clock between the DAC and DDC. With my headphone setup (in Sig), I regularly find that treble is too hot for many poorly recorded tracks which I don't like.
It's always been my impression that Termie Plus is a bit bright, whilst the Holo May KTE3 is smooth. About to place an order today but I did some research and found this thread Holo May KTE 3 Impressions and thoughts. From various comments in this thread, the May KTE seems to sound harsh and dry. As I have to buy this blind (not possible to audition where I live), I just wanna check with you guys, with headphones setup (Susvara / VC / Utopia 2022) and my amp (V281), how high is the tendency of this DAC to sound harsh/bright/dry (comparing with my Termie Plus now), if I put it in my system.
Thanks
May 7, 2024 at 5:39 PM Post #1,273 of 1,319
Thanks
The May is definitely not a bright or harsh DAC, especially in NOS. Make sure you let it warm up properly before making a judgement call (in my opinion 24 hours).
May 8, 2024 at 10:26 PM Post #1,274 of 1,319
Thanks
May is not bright at all. It is one of the most natural sounding DACs I have heard without sounding too thin. Compared to my analog set up which costs 3x more than May, sounds pretty smiliar than different. I just listened May with Joseph Audio perspective2s for few hours. I thought I knew the sound of May based on my long term use with previous speakers I owned, but with the Perspectives, boy May sounds nothing like I heard before. Not earth shattering different but enough so that makes me to think that associated equipments are very important to get most out of May. I definitely prefer May with speakers. Headphones can't provide that scale and visceral feeling that I get from the speakers.
May 9, 2024 at 12:04 PM Post #1,275 of 1,319
Hi guys. How do you usually connect the May to the PC...? Directly to a USB output of the PC or do you recommend a Sotom-type audio signal regenerator, or a ddc like Singxer or do you think that the isolation and quality of the USB connection of the May is sufficient and nothing in between is necessary...?
Thanks for your opinion....
