BrianS
- Jan 6, 2004
I plan on seriously upgrading and replacing my current headphone system soon once I have my own place to live. I want a singlepower amp, either the sds-xlr or es-1 and am currently learning towards electrostats namely the omega 2. I have not ruled out a dynamic system yet as new phones are always being introduced and it gives more variety and room to change.
I think a max budget of 10k for source and 10k for amp should be good for this system if not more money towards an amp and less for the source. This should leave money for tweaks mentioned below, assume total budget of 25k or less. I cannot decide between the following configurations. Any input will be appreciated.
amps:
singlepower sds-xlr
singlepower es-1
or even a singlepower ss (how much?)
sources:
apl dac/transport 7k
apl denon 3910 5.5k (discontinued?)
ayre c5xe 6k
used emm labs combo dcc2/cdsd 9k
used esoteric x-01 limited 8k
esoteric x-03 se 7k
gnsc modded ra opus 21 5k
edit: i should consider a used meridian 808 as it plays cd/rw and mp3 as well
Phones:
hd650 balanced
black dragon balanced gs1000
stax omega2
I would like to leave some money for cables, a rack, isolation, psaudio p500, shipping, and more importantly, TUBES. I think the esoteric, the emm, or the ayre are good investments because they are upgradeable and the ayre does play almost every disc. I will audition as much as possible but still appreciate opinions. If you have either of these amps what options did you get? PM me or post here. What was the total cost of your preferred tube setup for the above mentioned amps?
My sound/preference:
Detailed, airy, impact good but not necessary, textured, weighty, with good soundstage, imaging, and separation. I like to focus on a certain beat or sound in a song as I have noticed is easier with electrostats. If it can be done in a high-end dynamic system let me know. Comfort is a requirement (i think hd650 do not clamp hard if stretched out and are very very comfortable). I will hunt for a used player but do not feel like waiting around for a discontinued and rare headphone (ie, he90 he60, l3000, r10, 010).
I am leaning towards an x-01 limited and es-1 with omega2.
Thanks a bunch,
Brian
edit: typo and addition to source list
amps:
singlepower sds-xlr
singlepower es-1
sources:
ayre c5xe 6k
esoteric x-03 se 7k
Phones:
hd650 balanced
stax omega2
Thanks a bunch,
Brian
