ZMF Verite
Discussion in 'High-end Audio Forum' started by heliosphann, Oct 3, 2018.
198 199 200 201 202 203 204 205 206 207
209 210 211 212 213 214 215 216 217 218
  1. Monsterzero
    I call it like I hear it Bon. No single headphone will appeal to every single member of this forum,otherwise this forum would be out of business.
    Like I said though,in my system,with my ears/gears, and the sound I prefer,the VC is the best headphone ive yet to hear.
    FWIW I feel so strongly about the VC that my Auteurs are in the classifieds.
  2. UntilThen
    I'll keep this forum in business. :)
    Verite Open is the best sounding headphone to my ears.... until the next headphone.
  3. bryceu
    I told my wife I was thinking of the buying the VC... I got a very big eye roll.
    “But don’t worry babe I’d only be keeping one not both...”
    JM1979 likes this.
  4. UntilThen
    That is the correct answer.
  5. Bonddam
    I'm trying to get myself to try the other pads. I'm still using the default pad just don't feel like going through the trouble.
    JM1979 likes this.
  6. bryceu
    Went ahead and built an extra long 10-ft cable for relaxed couch listening sessions that I anticipate in the near future. :o2smile:
    Pharmaboy, Zachik, whirlwind and 7 others like this.
  7. Bonddam
    I went ahead and changed the pads it was easy, now just sit back and listen. What I'm listening for I don't know.
    Darthpool and bryceu like this.
  8. Bonddam
    Very nice looking cable like the colors on the black.
  9. ProfFalkin
    I suggest listening for music.
  10. Bonddam
    you make it sound so easy.:ksc75smile:
    Darthpool likes this.
  11. UntilThen
    It is. One has just to enjoy the music. Read this statement and you'll know why.
    It has been said, and it is true, Harman have run tests, that the more discriminating you are in analysing sound, the less you enjoy the music. Think about that! Musicians are less picky about sound quality than we are.
    Wildcatsare1, Darthpool and jinxy245 like this.
  12. Zachik
    Very nice looking cable!
  13. KcMsterpce
    What??
    Yes, if someone spends time analyzing audio, it diverts attention away from strictly listening to the music for enjoyment's sake.
    The second sentence makes NO sense, though. Musicians (real ones, that really care about music) spend a TON of time seeking better instruments and gear to improve the tone/sound they are looking for. Additionally, musicians may have knowledge of theory and technique, spending more time thinking about how a song is structured, the choices made at certain points that may or may not be agreeable to that musicians' musical choices.
    Thus, musicians are more inclined to be critical and are constantly analyzing what is going on - from several different levels of complexity.
    Also: "It has been said, and it is true, Harman have run tests..." lol
    "All dogs to go heaven. It's true, there is science."
  14. nishan99
    In about +60 hours of burn-in with normal use + EDM when not using them and I can say with confidence that they DO benefit from burn in.
    What I noticed is the bass is less intense now and the the staging with the verite pads is enhanced significantly.
    I think also they are more detailed/transparent after burn-in, but I am not sure about that maybe it's because the bass is less intense now.
    Darthpool and zach915m like this.
  15. Phantaminum
    I experienced the same behavior while burning them in. Keep at it and believe it or not, it’ll get better.
