Zero Audio - ZH-DX200 Carbo Tenore | ZH-DX210 Carbo Basso (Carbon & Aluminium IEM) thread
Dec 30, 2013 at 3:59 PM Post #961 of 6,085
Grayson73
Dec 30, 2013 at 4:40 PM Post #962 of 6,085
Lifted Andreas
Formerly known as geko95gek.
United Kingdom
  Agree.  I didn't get a good seal with any of the stock tips.  I highly recommend the meelectronics double flange:
Clear - http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=140821138554
Black - http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=130745455297
You can also get them direct (DF-35 tips):
http://www.meelec.com/SearchResults.asp?Search=df-35&Submit=
Awesome, I might have to reconsider them then.
My upgrade to the HA-S500 arrived today though, the HA-S680 and I'm burning them in as I type this... so far the sound is pretty boomy but this was also true for the S500 so I'm not worried. They are definitely much, much more comfy than the S500.
Jan 4, 2014 at 7:36 AM Post #964 of 6,085
guido
The Bassos definitely improve out of my Supermacro 3 amp with the 75ohm switch enabled....tames the bass and clears up the highs...beautiful!
Jan 7, 2014 at 6:13 AM Post #965 of 6,085
Lifted Andreas
United Kingdom
  I am looking to hear the bassos if anyone would be willing to give me a shot.
anyone looking to part?
Doubt it mate,
Bassos are a keeper, and no one here will let them out of their sight.
I suggest you either order some from Amazon JP or look on eBay.
Looking good there, especially the Bassos + Tenores. Those tips look like Sony Hybrids if I'm correct.
Jan 7, 2014 at 12:29 PM Post #967 of 6,085
Lifted Andreas
United Kingdom
  tips are the large supplied with the Zero Audios...but identical to the large Sonys on my MH1s...
Ah fair enough.
They just look almost exactly like the Sony Hybrids.
Jan 9, 2014 at 4:09 AM Post #968 of 6,085
sidrpm
Member of the Trade: Wired For Sound
Happy to join this group - Got the Carbo Basso a couple of weeks ago from Indonesia. Really great pair....mistake I made was not getting the Tenore at the same time.
Using the Basso with Ortofon tips from musicacoustica.
Jan 9, 2014 at 7:24 AM Post #969 of 6,085
Lifted Andreas
United Kingdom
Congrats mate, glad you're enjoying them!
Interesting tip choice too, but I recon you should still try the M6 bi-flanges which are recommended by Basso and Tenore users.
Jan 9, 2014 at 7:45 AM Post #970 of 6,085
sidrpm
Thanks.
Will try and get hold of these tips asap.
Jan 9, 2014 at 7:58 AM Post #971 of 6,085
Lifted Andreas
United Kingdom
  Thanks.
Good luck!
The best place is eBay, check out the links on the 1st page.
Jan 21, 2014 at 6:35 AM Post #973 of 6,085
Lifted Andreas
United Kingdom
FiiO X3 DAP + Zero Audio Carbo Tenore = Epic synergy!!!
Playing my January 2014 mix which will be aired on http://trance.fm this Wednesday evening (8PM UK). Self promotion ftw!
