krsk77
- Dec 1, 2014
thanks for that, sounds fair. I might have to go with tenore's they seem to be more versatile. Any known "hacks" to improve their durability?
Actually yeah. They are very durable, but the cable protector is not.
That image is not what actually happens to the Tenore's. What gets broken in the Tenore's is the protector, not the cable, the left thing up there, which starts to have a crack/fissure after 2 months or so. The fix is really easy and works like a charm. You just have to super glue it, and that's it. Do it when you see a fissure. Bought mines October 2015, fissure appeared in December, I super glued them and 'till now they are great, not a single problem. And if you look at the repaired zone, it does not look as if it has been repaired.
Great thanks for that. I'll definitely do it. You got a pic of it just to make sure I know what you mean? I think I might also put some heatshrinks on the cable in places that could use some support.
Sent from my Nexus 5 using Tapatalk
