Zero Audio - ZH-DX200 Carbo Tenore | ZH-DX210 Carbo Basso (Carbon & Aluminium IEM) thread
374 375 376 377 378 379 380 381 382 383
385 386 387 388 389 390 391 392 393 394
  1. Zeebit
    That wasn't really my point. I was just asking if anyone experience losing bass quantity as their tenores age
  2. Raketen
    @Lurk650 Just curious what do you find to be better at same price or lower?
  3. Lurk650
    LZ-Z03a and Bette 10mm
    Raketen likes this.
  4. Akmola Lola
    i checked and i.Valux Bette 10mm looks cool, but LZ Zo3a looks kinda cheaply packed.. is this the one you meant?
    http://www.amazon.com/LZ-Z03A-Dynamic-Cancelling-Earphones-Headphones/dp/B01C2XK0D4
    but well looks can be deceiving.. if it compares to Tenores then these should be up there.
  5. Lurk650
    Yes that's them but if you get them from his store on Aliexpress using the app they are $24. Check out the Chinese products thread, tons of great gear for good prices
  6. Akmola Lola
    I saw that I.Valux impendance is 32 ohm and Lz Zo3 is 16ohm (same with Tenore, Adagio2 and Heaven II that i owned so far)..
    im not a technical audiophile (or an audiophile at all, i just enjoy good music) , does it means higher is better in layman understanding?
  7. james444 Contributor
    Can you get the cotton filter out again and check whether that makes a difference for bass?
  8. Zeebit
    No improvement. I stuffed it with cotton because the treble got harsh after removing the mesh.
    My Piston 3 has noticeably more bass than my tenore. Should this be the case?
  9. james444 Contributor
    Just wanted to rule out any side-effect on bass, that's why I asked. Anyway, if the cause isn't in front of the driver, that would only leave the back vent. Not very likely though that it would get clogged over time.
    Sadly, I haven't heard the Piston 3.
  10. Lurk650
    both impedance and sensitivity play a factor in how loud they will be at a given volume. Not the quality of the IEM. The Bette are easy to drive
    Also, an honorable mention is the VJJB K4, listening to them again after a few months with some Auvio Medium tips and they are damn good. $23 on AliExpress website and $16 shipped using the app
    Akmola Lola likes this.
  11. Akmola Lola
    thx for the education man.. ill be giving one of them a try once i decide which to get next month.. rite now im just enjoying my Heaven 2!
  12. Lurk650
    My best earphone I have, ever had, is my TK12. I got it for $120, one dynamic and two BA. Super easy to drive. Sounds really good OOTB but burn in for 300hrs and it's fantastic.
    Jumped to $150 but starting 3/29 if you order from the app it's $99 shipped
    2016 New MusicMaker TK12 Dynamically And BA 3 Unit Headphone HIFI Fever In Ear Earphone As K3003 DIY Custom Hybrid Headset
    http://s.aliexpress.com/mIrAzqQf
    (from AliExpress Android)
  13. Akmola Lola
    the reviews for this tk12 is really good too.. this is definitely in my list now but will wait another week to get it.. thx man
  14. Lurk650
    You could always message Easy and let him know you are a member on Headfi and ask if you could get the sale price now
  15. Akmola Lola
    i think ill wait a week as i have just got myself fiio m3, fiio Q1 n fad heaven 2 all at the same time haha..
