waynes world
- Jun 21, 2012
You can use cotton from a cotton ball or from a q-tip, as I think it's the same stuff. I used a very small amount, and pulled it apart with my fingers to make it less dense. It should look pretty sparse, with each fiber individually visible. It'll get a little more dense when you push it into the barrel. I've posted this a couple times but here's the pic again for reference:
I've tested this mostly cable up, but cable down once for an entire session. It shouldn't matter imo, but who knows.
And to clarify, TTS stands for typical Tenore syndrome, and refers to channel imbalance, with one side sounding louder than the other. This mod should fix that problem. If you try it out please report back with your results. Good luck!
Well, my TTS tenores have been left abaondoned for the last 2 months, and I figured it's about time to do the above mods. Instead of cotton, I used some angel hair stuff that my buddy provided to me for various nefarious modding purposes. Quite a process to get the stuff to stay in the driver without coming right back out again lol, but I managed to do so AND to even get the filter tape back on.
So now I am listening to my tenores for the first time in 2 months, and holy crap are they sounding good. I'm not sure if the angel hair has changed the sound for the better, or if I just forgot how great they sounded, but if they continue to sound this great AND the TTS is eradicated, then I'm a happy camper! Fingers crossed!
