Your opinion on the best pair of headphones less than $100
Dec 15, 2007 at 1:44 AM Thread Starter Post #1 of 14
xtengong
I'm sort of new to the audiophile world, so i don't quite know what would be a nice pair of headphones to buy. I'm on a tight budget of $100. I plan to use these headphones for almost anywhere i go. I was looking at the grado sr80's but i've been hearing that i would also need an amp for it, so i'm not so sure anymore. They can basically be almost any kind of headphones, just as long as their aren't that fragile and most importantly, sound really well.
EDIT: Just so you guys know, I will consider the sr80's to be somewhat portable for me because I would just wear it around my neck when i'm not listening to them, so any other headphones like them are also okay, just as long they aren't too chunky to be worn around the neck.
Dec 15, 2007 at 2:02 AM Post #2 of 14
The sr80s definitely do not require an amp. They sound great without one. Also consider the Alessandro MS-1, which is $99. Its a joint product between Alessandro and Grado. Do a search and read up on it.
Dec 15, 2007 at 2:07 AM Post #3 of 14
In order that I would pick:
Denon AH-D1000 - closed
Alessandro MS-1 - open
Grado SR-80 - open
Equation Audio RP-21 - closed
Grado SR-60 - open
KOSS Portapro - open
KOSS KSC-75 - open
KOSS Sportapro - open
Any of the above headphones will likely blow your mind with their sound quality. All are under $100, and all are easily driven without an amp (but of course could/would benefit from one).
Dec 15, 2007 at 2:19 AM Post #5 of 14
SR80 for open and RP21's for closed.
-Nick
Dec 15, 2007 at 2:52 AM Post #7 of 14
alright, i think i'll go get the ms-1's, and then go get the Go-Vibe 5 when i get more money afterwards. Is it important if i get the firmer doughnut shape earpads for the ms-1's or no? and are the cables really long?
Dec 15, 2007 at 3:03 AM Post #8 of 14
Grado SR-80 - open
Grado SR-60 - open
KOSS KSC-75 - open
I would say that the Grado's are the best bet here IMO. Closed Earphones may have some distortion in some parts of music, though.
Dec 15, 2007 at 3:39 AM Post #10 of 14
Originally Posted by Ranma13 /img/forum/go_quote.gif
Also keep in mind the Grados can be really uncomfortable unless you use the flat pads.
Or get bowl pads, or mod the stock ones. I actually preferred the stock pads to the moded stock pads.
Bowls felt better on my head, but weren't worth the price.
Dec 15, 2007 at 3:51 AM Post #11 of 14
IMO - The whole of the MS-line sounds great. Really, I don't care much for the normal Grado line *except for the RS1's*. The MS line I feel is more balanced overall with a little clearer and realistic presentation. While the Grado's do a great job with rock and strings, they are not so hot with many other types of music IMO! The MS series does a good job at doing most things well while still placing you very close to the instrumentation.
Dec 15, 2007 at 4:05 AM Post #12 of 14
nice choice. I really liked the SR-60 with my Go-Vibe V5.
Dec 15, 2007 at 5:26 AM Post #13 of 14
For under $100, I would recommend the Grados. I have used both the 60 and 80 and they both sound great without any amplification. However, they leak out a lot of sound so I would not recommend using them at a public place.
Dec 15, 2007 at 5:34 PM Post #14 of 14
thanks guys, i just ordered the ms-1's, and hopefully i'll enjoy it even more than the pair of sr60's my friend let me try out. thanks for all your help ^.^
yayy, one more step into the audiophile world xD
